5 members (klhansen, 52Carl, 55shaker, Shardean, Ponchogl), 87 guests, and 3 robots.
Topics128,022
Posts1,055,352
Members48,420
#1161490 04/20/2016 11:55 PM
I have a 1952 that I think still has the original front end, however it looks like the PO shaved 3 lugs off. Looks like the front had eight lugs... I was under the impression that 3100's had 6 lugs? I am counting eight with the five and three shaved off can anyone shed some light on this for me, thanks
1952 Chevy 3100 AD
1964 Ford Bronco
2006 Dodge 2500
If there is a metal ID tag on the cab between the driver's door hinges, post that code.
Photos in earlier posts look like a 3100, but there is no side shot of the bed (the 3600 bed is longer than the 3100 bed).
6 lugs on 3100 wheels and 8 lugs on 3600 wheels.
Do front and rear wheels have 8 lugs?
There are three rivets that hold the brake drum on that are often shaved off so aftermarket wheels will fit. Could you be seeing this?
My Blog
The rear was swamped out with a 1968 chevelle, it has five
1952 Chevy 3100 AD
1964 Ford Bronco
2006 Dodge 2500
1952 Chevy 3100 AD
1964 Ford Bronco
2006 Dodge 2500
I think you are right......still strange that it only has five, I guess the front end could have been changed as well
1952 Chevy 3100 AD
1964 Ford Bronco
2006 Dodge 2500
Looks like the PO swapped out the front hubs for '49-'54 Passenger hubs to convert it to 5 lug to match the rear.
Bill Burmeister
That is the hard part is figuring out what vehicle was used....the drum has the anti squeak springs aroud the outside, strange but at least the front and rear match...I am finding more and more of this truck that is not original...it is making this fun. Everyday I work on something and it is an adventure!
1952 Chevy 3100 AD
1964 Ford Bronco
2006 Dodge 2500
