7 members (greenie-reddy, klhansen, carbking, Mike B, Hotrod Lincoln, cmayna, Woodcmiami), 60 guests, and 2 robots.
Topics128,030
Posts1,055,421
Members48,422
#1161376 04/20/2016 3:16 AM
I have power, 12V, to my coil. But after hooking my dwell meter, I have no dwell. Do I have a bad coil or I am doing something wrong? My truck quit on my way home so had it towed. Changed my points and cond. and hope that was it, but no. And yes the dist. turn when you hit the starter. 53 3100 55 motor root
root #1161381 04/20/2016 3:46 AM
ODSS Lawman
ODSS Lawman
What did you set the points to? Did you see spark?
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
root #1161382 04/20/2016 3:56 AM
M Online: Content
You should ba able to make a few simple tests with a multimeter to see if you are getting 12v through the coil.
Take dist cab off and put a business card between the points (this makes sure they are open). Turn the ignition switch on and then test for 12v on both small posts on the coil (positive and negitive). If you don't see 12v on the negitive side then the coil is bad. Now check for 12v at the points, you should see 12v there as well. If you have 12v on the negitive of the coil and not at the points then the wire is broken between them.
Also check the high tension post on the coil to make sure it's making good contact and not all corroded up.
Hope this helps,
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
root #1161507 04/21/2016 1:45 AM
Don't know what I did, checked everything for the three time and finely got power to the points. Thanks Mike for the help with the coil troubleshooting. After I got power to the points got help with the stomp starter and got it dwelled. Put it back together and its alive. Drove to my toy shop and quit for the day. I think the cond. was the problem. root
root #1161622 04/21/2016 8:52 PM
I have found some points(new replacement ones) had a coating on the points. No corrosion, and no contact. Pulled a match book striker strip through and Contact! Glad I was taught that trick back in the day.
Steve H
