| | | Forums66 Topics128,052 Posts1,055,771 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I am putting my streetrod together and I reached down and moved the disconnected pitman arm. It moved slightly, so I took out my dial indicator and measured it. it moved .025inch. Is this normal or not? This is on a 93 S10 frame. I am using the s10 power steering. Should I try and adjust it for 0 play or is that acceptable? Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Feb 2000 Posts: 5,203 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,203 | I would hunt down a '93 service manual and see what the spec's are for that gear box. I would imagine thats a little to much movement. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | .025 is not much. But it REALLY depends are where you took the measurement. If you measure any arm that rotates, the distance is much greater farther from pivot point. But I'm not sure you are talking rotation or up down or sideways. .025 is really small nevertheless. If you mean one end is still attached to the box and you are measuring rotation, you are measuring all the gear backlash. No sweat.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | The steering box must be at the center point to have no slack, assuming you're measuring rotation, not vertical slack. There should be NO slack up and down. Count the turns from lock to lock, split the difference, and adjust the sector preload so there's a 10 inch/lb. rise in turning effort of the steering wheel shaft as the gear moves over center. That should eliminate any rotational slack. Jerry
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I am still all in pieces right now. Yes it is rotational not vertical. Thanks all. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Great advice guys, I managed to turn it stop to stop and then centered it. I now see .005 to .006 radial play. I feel a lot better about that, should I still try to adjust for 0 play? Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Wait until everything is set up and see how it is. | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | should I still try to adjust for 0 play? Yes. Adapt a socket to the input shaft and attach an inch/pound torque wrench, then adjust the sector preload bolt until you get a 10 inch/lb. rise in torque as you turn the gear across the center point. For instance, if it takes 5 in./lbs. to turn the shaft as you approach center, the reading should rise to 15, then drop back to 5 as you pass the high point. This assures zero clearance with the wheels straight ahead and no wandering. Once the steering system is installed, have a front end shop adjust the wheels for a straight ahead track with the steering gear centered. It used to be standard procedure to center point the steering gear and adjust the sector preload during a wheel alignment, but too many so-called alignment technicians have only seen rack and pinion steering and don't know how to adjust a worm and sector steering gear properly. Jerry
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Jerry, should there be the 10 inch pound rise with nothing hooked to the pitman as mine is? Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Yes- - -when a preload adjustment is done on the vehicle it's necessary to remove the Pitman arm, or otherwise isolate the steering gear from the rest of the system. Just clamp the steering gear into a vise and do the adjustment on the bench. Jerry
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
