| | | Forums66 Topics128,208 Posts1,057,452 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Maybe on a GMC?
A GMC pan and filler tube might be swapped into a Chevrolet?
These are guesses. | | | | | Joined: Feb 2004 Posts: 29,888 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,888 | Since the Hydramatic was used in numerous vehicles, it's entirely possible a pan from something like an Oldsmobile, Pontiac, Cadillac, Nash, Lincoln Continental, or even a Rolls-Royce might have been fitted to a Chevy truck! Jerry
| | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | I know of one 55 1st H-M truck that had the pan fed (dipstick tube) but it was done when the truck was owned by transmission shop and new owner was advised to keep it that way by the same shop. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | The truck's Main Trans Case does not have a fluid filler smoke stack cast into the case LIKE THIS 1954 Chevrolet MAIN CASE. It must of been ether 1958 or 1959 when GM changed the HM main case and stopped casting the smoke stack into the case. 1957 CHEVROLET TRUCK OPERATOR'S MANUAL, HM fluid Check Smoke Stack 1958 CHEVROLET TRUCK OPERATOR'S MANUAL, HM fluid Check (Not Available) Smoke Stack or Pan fed ?? 1959 CHEVROLET TRUCK OPERATOR'S MANUAL, HM fluid Check Pan fed This eBay auction Shows the smoke stack dip stack used from 54-58. part# 8605800 So the transmission in the truck in question is probably a 1959 model year transmission. 1959 was probably the 1st year GM started using a pan fed tube on the H-M. Anyone know where there is a online 1958 CHEVROLET TRUCK OPERATOR'S MANUAL? | | |
