0 members (), 104 guests, and 5 robots.
Topics128,266
Posts1,058,386
Members48,485
#116113 01/17/2005 10:43 PM
Anonymous
Unregistered
Anonymous
Unregistered
When mixing body filler I found it hard to find something that could be used as a mixing board and discarded without guilt or cost, but looking around the garage I could not identify something that fit the bill.
On the way to the parts house I noticed all the bandit signs and election signs posted along the road. I dislike these signs as visual pollution but recalled these are made from a plastic corrugated material that might be just what I need.
I pulled over and grabbed a few and cut them in quarter sections when I got home. They are just the ticket and I can use both sides before discarding.
If you are one of those people putting up those signs then I want to thank you for providing a solution to my problem.
#116114 01/18/2005 1:37 AM
Great idea! We are always looking for mixing boards. I have been using the lids off large plastic pails. We do have an election coming up too! There's just one problem - most of the election signs are of thin plastic like garbage bags which are then pulled over a wire frame - these are much cheaper than coroplast ones. However, I did see a coroplast "house for sale" sign on a telephone pole on the way home; it's illegal here to hang a sign on a telephone pole - better do my civic duty and take it down!
Gord
1954 1/2 ton 235 4 speed
#116115 01/18/2005 4:02 AM
I have to tell you guys, I went to an aluminum mixing board using a metal flexable spreader and a plastic spreader years ago and would never go back. You have a little squirt bottle of lacquer thinner to apply thinner to the mixing board and a scuff pad to scrub it clean. Then a rag to wipe dry. My tools are spotlessly clean at all times between mixings.
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#116116 01/18/2005 4:15 AM
Most autobody supply stores carry "onion boards"... A pad of disposable "paper"... Just mix, spread, tear a sheet and toss away. Fairly inexpensive..
Andy
A man is like an old truck... He will rust out before he wears out...
#116117 01/18/2005 3:38 PM
I've always used a leftover 8 x 8 ceramic floor tile. When I'm finished with a batch I scrape the excess off with a razor blade before it gets really hard. A little cleanup with lacquer thinner every now and then keeps it like new. The glazed finish on the tile will last forever.
#116118 01/19/2005 8:30 PM
I have used Chinet style paper plates in the past, seemed to work fine.
Paint & Body Shop moderator
