| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | | Anonymous Unregistered | | Anonymous Unregistered | When mixing body filler I found it hard to find something that could be used as a mixing board and discarded without guilt or cost, but looking around the garage I could not identify something that fit the bill.
On the way to the parts house I noticed all the bandit signs and election signs posted along the road. I dislike these signs as visual pollution but recalled these are made from a plastic corrugated material that might be just what I need.
I pulled over and grabbed a few and cut them in quarter sections when I got home. They are just the ticket and I can use both sides before discarding.
If you are one of those people putting up those signs then I want to thank you for providing a solution to my problem. | | | | | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | Great idea! We are always looking for mixing boards. I have been using the lids off large plastic pails. We do have an election coming up too! There's just one problem - most of the election signs are of thin plastic like garbage bags which are then pulled over a wire frame - these are much cheaper than coroplast ones. However, I did see a coroplast "house for sale" sign on a telephone pole on the way home; it's illegal here to hang a sign on a telephone pole - better do my civic duty and take it down!
Gord 1954 1/2 ton 235 4 speed
| | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | I have to tell you guys, I went to an aluminum mixing board using a metal flexable spreader and a plastic spreader years ago and would never go back. You have a little squirt bottle of lacquer thinner to apply thinner to the mixing board and a scuff pad to scrub it clean. Then a rag to wipe dry. My tools are spotlessly clean at all times between mixings.
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Jun 2004 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 100 | Most autobody supply stores carry "onion boards"... A pad of disposable "paper"... Just mix, spread, tear a sheet and toss away. Fairly inexpensive.. Andy
A man is like an old truck... He will rust out before he wears out...
| | | | | Joined: Mar 2004 Posts: 71 Member | | Member Joined: Mar 2004 Posts: 71 | I've always used a leftover 8 x 8 ceramic floor tile. When I'm finished with a batch I scrape the excess off with a razor blade before it gets really hard. A little cleanup with lacquer thinner every now and then keeps it like new. The glazed finish on the tile will last forever. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I have used Chinet style paper plates in the past, seemed to work fine.
