0 members (),
109
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 13 New Guy | | New Guy Joined: Dec 2014 Posts: 13 | Does anybody have a paint code or source for the chartreuse color early '57 car engines were painted? Or does it pretty much have to be color matched? I haven't been able to find anything.
I want to paint mine that instead of gray.
1957 Chevy 3200 1971 Jeep CJ-5 1983 Chevy K-10
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | You will not find Chevrolet engine paint codes, they were never published. The best you can do is look at pictures of '57 cars with the 265 and see what shade works for you. Mike B  | | | | | Joined: Dec 2014 Posts: 13 New Guy | | New Guy Joined: Dec 2014 Posts: 13 | Thanks for the replies. I kinda figured I'd be on my own. I have both those pictures and I really like the color of the first one. Guess I can try and find some place that can color match a picture.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you like it, go with it.
No one knows what shade is "correct". | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | From examples I have seen through the years I would say NO they are not the same color. The 261 was yellow, kind of like this color; http://www.crayola.com/explore-colors/unmellow-yellow.aspxThe 265 was Yellow Green, kind of like this color; http://www.crayola.com/explore-colors/chartreuse.aspxPut these two color pages side by side and you will see the green in chartreuse. As Tim said, there is no right or wrong. This is just my opinion and it's not ment to stir things up, engine color mix info was never published. Mike B  | | | | | Joined: Dec 2014 Posts: 13 New Guy | | New Guy Joined: Dec 2014 Posts: 13 | I'm not trying to stir things up or find the "one true" color. Just looking for something in the realm of close enough. I just want to paint my motor something other than gray, and would like to use a color that was used on some kind of truck engine. Thank you for the replies.
| | | | | Joined: Sep 2011 Posts: 131 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 131 | My 1962 261 was green, I used the paint on a generator mounting bracket bolt that had probably never seen the light of day. Took it to a paint supply place and they used a spectrograph to obtain a formula. They used this to mix up a quart of high temp. machine enamel. Putting that old bolt head up to the now newly painted engine my old eyes could not see a difference. My thinking is the engine colours were set due to passenger or commercial, size of truck, what displacement and possibly what plant built it. Grey, yellow, green or orange. Post a photo, I bet it will look great! Howie
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine 4 1966 Plymouth VIP 5.7 GenIII Hemi 5 1966 Imperial Crown Coupe 440 engine | | |
