5 members (J Lucas, Gray_Ghost, msmall, 2 invisible), 93 guests, and 2 robots.
Topics128,075
Posts1,055,918
Members48,429
#116091 05/07/2002 6:28 AM
1 Offline
The metal frame around the door glass is in need of paint. I took the glass out to have new glass cut. But b-4 I put the new one's in I need to paint the frames. Was the frame gloss black, flat black, or semi-gloss black or was it even black???? Any help would be mucho appreciated.
Thanks Oh ya were working on a 1950 Chevy halfinton,with a custom cab. grin
Been driven and loving my 50 for 27 years. With the same stuff Chevy put in it from the get go.
I believe those trim pieces are cab interior color (champagne). I hope so because I just painted mine that color.
1 Offline
Hay thanks for getting back at me. The metal around my window frame's are stainless steel. The metal Iam talking about, goes around the glass and sides in the window channel and hold the glass to the regulator.
Should be semi-gloss black from what I remember.
I agree that most I have seen are black. Whether gloss or semi-gloss I couldn't tell you.
#116096 05/09/2002 12:10 AM
1 Offline
thanks everbody I guess Iam going to squirt them semi-gloss black. Or has anybody ever changed the size of the window channel and ran a window without the metal frame ? I was quoted a price of $225.00 to install new glass in the front,and the back, not the corner windows. I supply the new rubber. What do you all think sound O.K.
not too bad if they supply the glass too.Did you know that you can get smoke tinted glass for the flat window replacement?
.It is safety glass and it is legal,not too dark.
