| | | Forums66 Topics128,076 Posts1,055,925 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 8 New Guy | | New Guy Joined: Dec 2009 Posts: 8 | I know this question has been asked before, but I'm trying to figure out what size radial I can use to replace a 6.50x16 bias ply. Any info is appreciated and pictures for comparison would be nice too. Thanks, Greg.
51 chevy 3100
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Light Truck 215/85R16
The recommended rim width is wider than our original wheels/rims, but mounting that side radial on a 4.5" rim will make the tire taller (lowers RPM) and narrower (makes the tires look more "natural" for the old truck).
Some people argue that mounting on a narrower rim puts strains on the sidewalls. That might be true for Le Mans racing, but no one has posted experiencing side-wall failure.
One pair on my trucks are 12 years old - well beyond the "warranty" period. | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | Some of the manufacturers such as Coker make a radial that size although they are quite dear. I have 6.50 x 16's on my '51. | | | | | Joined: Oct 2015 Posts: 338 Shop Shark | | Shop Shark Joined: Oct 2015 Posts: 338 | If you search the web, there are some cool tire sites that compare sizes visually. They also will give you speedometer/speed/rear gear ratio and other estimates. | | | | | Joined: Jul 2014 Posts: 8 New Guy | | New Guy Joined: Jul 2014 Posts: 8 | I used blackwall Yokahama Geolander LT215/85 R16. Very reasonable price at $100 ea from Discount Tire. https://goo.gl/photos/Pc5MmSJ5jeFZ7uCf6 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Light Truck 215/85R16
One pair on my trucks are 12 years old - well beyond the "warranty" period. Agreed. That size is a pit wide for the stock rims, but it is the closest you'll find. On the sidewall support issue, in my experience, it's more of a handling issue than a tire failure problem. At higher speeds (50+), the sidewalls lack proper support on a too narrow wheel, and this can lead to severe wander. However, for the typical use these trucks see, and the speeds generally run, it shouldn't be a problem.
Bill Burmeister | | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | Just want to mention that the 215/85/16 won't fit on the spare tire carrier on the side of the truck. I"ll be getting a 195/80/16, is about the same as size around as original. I"ll just use it for a spare. | | |
