| | | Forums66 Topics128,037 Posts1,055,576 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 17 Member | | Member Joined: Jan 2002 Posts: 17 | The metal frame around the door glass is in need of paint. I took the glass out to have new glass cut. But b-4 I put the new one's in I need to paint the frames. Was the frame gloss black, flat black, or semi-gloss black or was it even black???? Any help would be mucho appreciated. Thanks Oh ya were working on a 1950 Chevy halfinton,with a custom cab.
Been driven and loving my 50 for 27 years. With the same stuff Chevy put in it from the get go.
| | | | | Joined: May 2001 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: May 2001 Posts: 71 | I believe those trim pieces are cab interior color (champagne). I hope so because I just painted mine that color. | | | | | Joined: Jan 2002 Posts: 17 Member | | Member Joined: Jan 2002 Posts: 17 | Hay thanks for getting back at me. The metal around my window frame's are stainless steel. The metal Iam talking about, goes around the glass and sides in the window channel and hold the glass to the regulator.
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Should be semi-gloss black from what I remember.
| | | | | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | I agree that most I have seen are black. Whether gloss or semi-gloss I couldn't tell you. | | | | | Joined: Jan 2002 Posts: 17 Member | | Member Joined: Jan 2002 Posts: 17 | thanks everbody I guess Iam going to squirt them semi-gloss black. Or has anybody ever changed the size of the window channel and ran a window without the metal frame ? I was quoted a price of $225.00 to install new glass in the front,and the back, not the corner windows. I supply the new rubber. What do you all think sound O.K.
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | not too bad if they supply the glass too.Did you know that you can get smoke tinted glass for the flat window replacement? .It is safety glass and it is legal,not too dark.
