0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#116085 01/15/2003 2:59 PM
Before hanging the doors for my truck I wanted to rebuild the hinges but can't for the life of me figure out how to get the old pins removed?! Anyone know the trick to getting these old rusted pins out?
Along a related line, when hanging the doors on an AD pickup are there any tricks I should know about ahead of time to help align things correctly? Thanks for all the help.
Steve
55 1st Series 3/4 ton
Someone will chime in but I believe they need to be drilled out. An oversize pin is available as a rebuild kit.
54 3100 with 235
62 flatbed dump C60 with 261
stevejumpr,
For my last 12 hinges (last two trucks), I used a hydraulic press to remove the pins. After the pins were removed, if the various holes had to increased for bushings or oversized pins, I used a drill press.
You might be interested in this technical article:
http://www.classictruckshop.com/door_hinge.asp
As far as rehanging the side-doors properly: practice and patience and a lot of time are required. Maybe someone else will have more helpful advice on rehanging the doors.
Good luck,
Tim
I drilled my pins out, except for one that came out with a hammer & punch. Make sure your drill stays centered & plumb.
My doors looked perfect until I put the weatherstripping on. I've heard that Steele Rubber makes softer weatherstripping than that offered by the usual suspects. It's not been substatiated, so I plan on trying it in the spring to see if it makes a difference.
http://www.steelerubber.com/
If you go to the online catalog and only see gobbledygook copy and paste it into Word. Word translates it OK.
Good stuff. Thanks for the advice. I was afraid I would have to drill/cut the pins out, but that is how things have gone for the whole truck. Why have something change now. smile Thanks much.
Steve
I had good luck with Steel Rubber products. I had bought 2 different seals from two different venders for the windshield of my '37. Each was to stiff to let the windshield close all the way. The one from Steel was really soft and sealed right up. Now it closes right up to the stops and really cut down on wind noise. I believe all there stuff is USA made and priced real close to everybody elses. Joe
