| | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Hello
I have search the form for the answer but can't quite figure out what way is right conflicting ways
springs go under the frame support seems to be confirmed
the 2 rubber gaskets
one say's they both go under the support between the support and frame
the other post says one between the support and frame and another under frame and then springs
any idea's Thank you
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Items need to install radiator: Hex Head Bolts 3/8" X 3" (2) Washers 3/8" X 1 1/4 diameter (6) Lock washers 3/8" (2)Place bolt with washer through radiator support frame DO BOTH BOLTS AT SAME TIMEUnder support frame place both rubber pads on bolts Next place bolts through frame Next install washer (regular 3/8" washer) Next install spring Next install washer Next install lock washer Next install nut & tighten to secure radiator mounting frame to chassis There are 4 small bolts (1/4" X 3/4") that bolt the top of the radiator support rod to the "bull nose" plate. Harold 4/24/16 Add Photos of springs & washers plus support rod to fire wall. Spring, Washer & Support Rod
Harold Is a restoration ever finished? | | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Thanks Harold
now I can start puttin her back together | | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Mine came without springs. Anyone know where to find the right ones/size?
| | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | When I was at this stage about 5 years ago I had a similar question. My '46 also came without the radiator springs. I found and had good results with hood fit etc with some after market springs. The bad news is I can't recall the specifics. I have checked my notes, receipts and done a search in the Stovebolt without success. Someone suggested a FLAPS and as I recall they gave a recommended application. I am thinking now it may have been a suggestion in Tim Sheridan's old website???? I recall buying them at NAPA, off a revolving display rack. As I recall, they were for a foreign import--maybe Nissan? The package came with the spring, two packages were needed, bolt, nut and washers. Only the spring was used and SAE bolts etc were substituted. Does any of this parts info ring any bells with anyone else? UPDATE::: I found the receipt and did a search on the NAPA online catalog. The part number is: 600-3120 --Stud and nut kit. Hope this helps.
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 |
40 Chevy 1/2 ton
| | | | | Joined: Oct 2008 Posts: 298 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 298 |
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | See my edit in second post above. Spring, Washers and support rod Harold
Harold Is a restoration ever finished? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I used some oriental car valve springs for my GMC T-18.
Ed
| | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Excellent info...thanks to all. | | |
