7 members (Otto Skorzeny, J Lucas, klhansen, Tronman, electors, 78buckshot, 1 invisible), 106 guests, and 4 robots.
Topics128,042
Posts1,055,497
Members48,424
#1160595 04/15/2016 6:40 PM
Hello
I have search the form for the answer but can't quite figure out what way is right conflicting ways
springs go under the frame support seems to be confirmed
the 2 rubber gaskets
one say's they both go under the support between the support and frame
the other post says one between the support and frame
and another under frame and then springs
any idea's Thank you
Items need to install radiator:
Hex Head Bolts 3/8" X 3" (2)
Washers 3/8" X 1 1/4 diameter (6)
Lock washers 3/8" (2)
Place bolt with washer through radiator support frame
DO BOTH BOLTS AT SAME TIME
Under support frame place both rubber pads on bolts
Next place bolts through frame
Next install washer (regular 3/8" washer)
Next install spring
Next install washer
Next install lock washer
Next install nut & tighten to secure radiator mounting frame to chassis
There are 4 small bolts (1/4" X 3/4") that bolt the top of the radiator support rod to the "bull nose" plate.
Harold
4/24/16 Add Photos of springs & washers plus support rod to fire wall.
Spring, Washer & Support Rod
Harold
Thanks Harold
now I can start puttin her back together
Mine came without springs. Anyone know where to find the right ones/size?
1946 1.5-Ton Chevy Shorty Bus
All my best --- Tango
When I was at this stage about 5 years ago I had a similar question.
My '46 also came without the radiator springs. I found and had good results with hood fit etc with some after market springs. The bad news is I can't recall the specifics. I have checked my notes, receipts and done a search in the Stovebolt without success. Someone suggested a FLAPS and as I recall they gave a recommended application. I am thinking now it may have been a suggestion in Tim Sheridan's old website???? I recall buying them at NAPA, off a revolving display rack. As I recall, they were for a foreign import--maybe Nissan? The package came with the spring, two packages were needed, bolt, nut and washers. Only the spring was used and SAE bolts etc were substituted.
Does any of this parts info ring any bells with anyone else?
UPDATE::: yahoo
I found the receipt and did a search on the NAPA online catalog.
The part number is: 600-3120 --Stud and nut kit.
Hope this helps.
40 Chevy 1/2 ton
mount spring pic.
My '46 1/2 ton
See my edit in second post above.
Spring, Washers and support rod
Harold
Harold
Crusing in the Passing Lane
I used some oriental car valve springs for my GMC T-18.
Ed
Excellent info...thanks to all.
