0 members (),
135
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 142 Member | | Member Joined: Apr 2002 Posts: 142 | O.K. ,I am taking my cab down to bare metal, a friend suggested etch primer ,so I went to my OREILLY'S auto parts and bought some.It is Dupont nason 491-17 etch primer.I am confused on what primer I can use on top of it , someone told me I could not use epoxy over it, did not find info on Dupont's site.Thank's in advance!!! | | | | | Joined: Jul 2002 Posts: 46 Member | | Member Joined: Jul 2002 Posts: 46 | I would use uro primer that way you have a high build and a lot to sand and get rid of scratch marks
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | You can use etch primer but you can't put plastic filler over it. So on those areas you need to remove it first again. I decided my first coat would be epoxy primer. That way you can add filler, sand, add high build primer, sand and paint with your final product.
54 3100 with 235 62 flatbed dump C60 with 261
