5 members (mason86, 1955 1 Series, Oldcaliforniakid, Hotrod Lincoln, TexasA&M48Truck), 104 guests, and 2 robots.
Topics128,069
Posts1,055,884
Members48,428
O.K. ,I am taking my cab down to bare metal, a friend suggested etch primer ,so I went to my OREILLY'S auto parts and bought some.It is Dupont nason 491-17 etch primer.I am confused on what primer I can use on top of it , someone told me I could not use epoxy over it, did not find info on Dupont's site.Thank's in advance!!!
I would use uro primer that way you have a high build and a lot to sand and get rid of scratch marks
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
You can use etch primer but you can't put plastic filler over it. So on those areas you need to remove it first again. I decided my first coat would be epoxy primer. That way you can add filler, sand, add high build primer, sand and paint with your final product.
54 3100 with 235
62 flatbed dump C60 with 261
