2 members (baldeagle, Rusty Rod), 74 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#1160301 04/14/2016 6:30 AM
I tried searching this one ,but could not find an answer,I have a 1962 gmc 3/4 ton 8 bolt 16.5 inch wheels,is there an 8 bolt 16 inch rim that will swap onto this?
1962 GMC 920 step side 261 4 spd
Crusing in the Passing Lane
Sure, just be careful to measure the ID of the center hole, offset.
Ed
A 16" Ford 3/4 ton wheel will work. Dexstar trailer wheels are patterned after the Ford wheels and they fit too. The hub on a Ford ore Dexstar is a little larger than GM, but that makes no difference because they are stud piloted anyway.
http://www.etrailer.com/dept-pg-Tires_and_Wheels-sf-Wheel_Only-sz-8_on_6~1|2_Inch-pc-16_Inch-pm-Dexstar.aspx
Make that a 1998 or earlier Ford wheel.
Cletis #1160641 04/15/2016 10:46 PM
F 250/350 only. The Econoline E 250/350 still uses the 8 x 6.5 bolt pattern.
Bill Burmeister
That is good to know.
