7 members (3B, Tinker5, Gdads51, Bill Hanlon, Bills Auto Works, WICruiser, 2-Ton), 135 guests, and 4 robots.
Topics128,195
Posts1,057,378
Members48,469
Ive had a look at the spare diff yesterday and its a better highway ratio than whats currently in it, as I have to redo the rear springs, I'm just going to change it out drum to drum, my question is it has a leak at the pinion seal, is the pinion pre loaded via a crush spacer in these or can I undo the pinon nut and lift off the yoke? and change the seal out?
Also and this is mostly for the Sydney Melbourne Brisbane guys
I'm after some 7.00 X 20 10 ply tyres
I'm very particular when it comes to tyres.
They must be black, round & new (not been in someones shed for 20 years) other than that I'm open to suggestions
Old world lamps and tyres have real brands but want more money than I'm prepared to spend
Antique tyres have Lu He brand for a more respectable price but I'd like to do a bit better
Does anyone have a supplier that's got good prices on these things, as I said before round black and new is my only stipulation
3B Online: Content
3 Online: Content
Hy TheYeti, I assume both the rear axles are Eaton, is my assumption correct? Most of the larger differentials do not use a crush sleeve, just a lot of torque to get the bearing preload. Have you checked the brakes on the "new" rear axle to make sure they are of the same type? As to the tires, in North America 8.25X20 seems to be the smallest size easily available.
Yeah the diffs are the same physically, I'm assuming Eaton (Im not a fan of their off highway stuff but I'm not about to reinvent the wheel for something else)
Yes the brakes are identical (unfortunately while the shoes are in much better condition (not oil soaked and have about 50% remaining the wheel cylinders are in similar condition to the other diff)
I've never seen a 5 ton '51 model Chevrolet. Made in the USA '51 Chevrolet trucks were rated no higher than 2 ton. I've seen some Canadian built imports rated as high as 3 ton. What series is yours ?
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Hi Spanky, Mines 1100 series it is a factory 5 ton but in Australia they came in as rolling chassis and the bodys were built locally
I'm assuming the chassis etc was built in Canada as alot of the brake components are stamped as such
Got any pictures we can see ?
Spanky Hardy
1950 GMC 250 1-Ton
yeah Spanky
heres a photobucket album
http://s220.photobucket.com/user/theyeti72/library/
Nice looking truck.
its a far truck
looks good from afar but is far form good
3B Online: Content
3 Online: Content
Hy Guys, in Canada an 1100 series is a 1 1/2 ton truck with a GVW of 11,000 lbs.
that would be about right 11,000lb would be 5.5 ton wouldn't it?
The "ton" rating is nominally what you could tote on the back of the truck. However it is no longer an accurate number and has become just a guide to general size of truck. The actual payload capacity is reduced by the bed weight, a considerable variable.
11,000 lb gross vehicle weight is total of everything, truck, bed, fuel, driver, load and everything as it rolls down the road. 11,000 lb less all that only leaves room for only a few thousand pounds of payload, something like your nominal "ton and a half" rating.
•1952 Chevrolet 3800 pickup
---All pictures---
That's a 1 1/2 ton truck in the USA.
Spanky Hardy
1950 GMC 250 1-Ton
that would it then so I guess its just a small bolt then frown
Actually I don't care, I'm loving this truck and I'm [censored] I haven't had a chance to throw a spanner on it since Easter Monday
1 1/2 ton still qualifies as a Big Bolt on this forum. wink
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
1 Offline
I looked at the photos and noticed the wheel cylinders. I've been overhauling mine for years. In fact I carry a spare kit on the road in case of a failure. Hone them out to smooth install cups with suitable grease, put never seize compound on the pistons and put them in. The never seize has stopped pistons from sticking in the bores and stopped rust. Have not had a failure on my daily driver in many years.
1951 3800 1-ton
In the DITY Gallery
Good advice
Had the pleasure of meeting Andrew Phillips (not sure of his username) today, he posted something on a facebook group we both frequent and we got to talking next thing you know I now have a good second hand steering box and a good seat bace and back for my truck.
He's a top bloke and only too happy to help
3B Online: Content
3 Online: Content
Hy TheYeti, that's great news!
3B Online: Content
3 Online: Content
When I met with Andrew he told me there were a lot of diagrams etc on here, I'm chasing an electrical diagram for my old girl.
my original plan was to scrap the existing wiring but I pulled the gauges out yesterday and all the wiring in the dash is good and the bulk of it is else ware as well, its really only the wiring to the tail lights and some of the engine harness thats chatty.
What I'd like is a wiring diagram as I want to go right through it looking for faults etc and repair / replace the sections where there are issues and tidy a few things up along the way.
This might not be right for a 1.5 ton truck?
1951 Truck Wiring - USA Chevrolet truck
Tim, I think that is right for all sizes of AD Chevy with possible exception or variation on lengths for the COE.
Otherwise the length between tail light and the main harness would change with wheelbase but the front harness would be the same best I can tell.
Grigg
---All pictures---
From what I can work out by quickly looking at whats there it looks right to me
Thanks heaps
Hi guys
It’s been in hiatus for a little while but we’re back on
I’m dropping in a V8 and one of the local requirements is a collapsible steering column.
I want to keep the factory steering and box, what are you guys doing for collapsible column?
Welcome back. After 4 years I’m impressed you could remember your password.😁 Time to get on it and finish it up. Working on them is fun but driving them is way funner!🛠
TheYeti,
is that blue car a 37 Chev? The north American version ran that cowl crease detail back across the side door and the back window was one piece. That is really interesting.
1951 1 Ton Completed
He problem with being a little spoilt for choice is it hasn’t been a priority until now 😉😉😉
Originally Posted by truckernix
TheYeti,
I can’t think of the blue car your talking about, but I think your referring to the Matt black Australian body 37 Chev I have, and yes it has no door crease and the stereotypical Aussie duel rear window
I have a 38 ford that has the same
[img]https://i.postimg.cc/Dw5wdKkW/D0555705-48-FC-4040-A53-C-A6-D31-E00-D6-B4.jpg[/img]
[img]https://i.postimg.cc/XrRbJLZ5/537-B424-C-4-B7-D-4-EC5-AFE2-88089-DDAA117.jpg[/img]
I can’t work out how to post pics
But this is my truck if anyone is interested
https://postimg.cc/gallery/shhrvFt
Love that '38 Ford!!
Rich
1947 Loadmaster
The very simple instructions for posting photos in your posts is in the left margin of every page. ABSOLUTELY No Need For Links!
Thanks, those are all so very cool!
First attempt at photos in this forum
There ya go! Good job.
All good
Most forums want you to host the images on another site, so that’s what I’m used to is all
I’m easy either way
We used to have to do it that way but last year we moved into the 21st century.🤣
