2 members (baldeagle, jmoore),
155
0
Mod | | | Forums66 Topics128,037 Posts1,055,469 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 129 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 129 | Has anyone added an auxiliary transmission, overdrive transmission or different rear end to gain a little more speed? I love driving my 1940 1-1/2 ton around but, as we all know, you max out at 45-50 mph. To me it is more of a safety issue. Every year, with more traffic, it seems there are more close calls with someone coming up on the back of the truck going 70-80 mph. I sure don't want to get carried away, as it still has stock brakes, but it would be nice to cruise at 55-60 mph. Is there a Spicer/Brown-Lipe that fits in the closed driveline? What type of overdrive was available? Thanks for any help or suggestion. | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | I wasn't aware that 1-1/2 tons had enclosed driveshafts. If you have an open driveshaft you can put an auxiliary behind the main transmission. I did this many years ago and am still driving the truck. The one to look for is a Spicer or Brown-Lipe 5831A. These were found in many tandem axle trucks, dump trucks are most common in my area. Or the next bigger transmission would be a 6231A. There is a fellow who advertises in the ATHS magazine who has at least one of these.
The "A" designation is important as those have the 1.24 underdrive and 0.86 overdrive the other have a 2.xx underdrive. Those are no use on the road; the under is just for crawling around on construction sites or farm yards. So you only split the main box gears twice rather than 3 times as with the A models. It makes a big difference on the road to have the extra gears.
You could also put a two-speed axle from a later truck but they were usually geared pretty low to accommodate 9.00 X20 tires. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | 5531 would also work, 6231 is very large, but will also work.
Ed
| | | | | Joined: Aug 2006 Posts: 129 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 129 | 1940 had a 2-piece enclosed driveshaft all the way from the rear end to the transmission. I believe they changed to open driveline in 1941 on the larger trucks, IIRC. | | | | | Joined: Mar 2011 Posts: 107 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 107 | I'm not aware of a box that specifically fits your enclosed driveline, but I have seen literature describing boxes that could be paired to enclosed drivelines, of course they required changes to the driveline enclosure. Finding one for your application will not be easy even if one existed 75 years ago. I have a 5831C in my truck, all 3 ratios are road usable and split the 4 speed both up and down in every gear sequentially. See videos below for an example of how it drives. Overdrive is 0.85 so you can add about 17% to your top speed on level ground. As always, the rest of the truck especially brakes will need to be in great shape if you are going faster. | | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | Check out this Wed Site http://6066gmcguy.com/ Look at the Spicer 5831 Aux Transmissions the ones you want are the ones with 0.73:1 overdrive. Any questions call me 1-262-392-2989 Marv. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I think the best bet for your '40, would be to change to an open driveline, lot of work but there are lots of unused rears and trans' around, might as well get an updated rear, two speed might get slightly better ratio(6.5:1?) so can fit in a Brownie while doing the work.
Is your wheel bolt pattern 5/10 on 7.25" or ? Could use 420, 465 4 speeds or 540 5 speed.
Good luck.
Ed
| | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Are you still running a 216? Good luck with developing enough torque to pull an overdrive. Running downhill with a tailwind just isn't an option all the time- - - -eventually you've got to do some climbing. Jerry
