4 members (lumbersawyer, Hush, 2 invisible), 64 guests, and 3 robots.
Topics128,026
Posts1,055,407
Members48,422
#1159732 04/11/2016 1:34 PM
I would like some advice on replacing what I think is a bad/collapsed? lifter. Basically my son had a leaking pushrod cover so we decided to replace them. This is on a 1965 K10 292. On close inspection the #4 lifter appears to have an internal part that has tilted sideways and pushed the rod to the side. From what I can gather there is a clip to hold that in place? Anyway I read this quote while searching for answers.
Quote
Lifters on the 292 are easy to change and not expensive.
That being said, how easy, where do I get replacements? Really don't want to be taking the head off or removing camshafts, etc. Is it as easy as loosening that rocker arm, pulling rod to side, replace lifter, and readjusting? I know that I need to probably find a manual on the procedure to get the adjusting specifications(those would be helpful if someone knows them). I've had experience with the 216 and have that manual, not the 292's. Long story short can I just replace the one lifter alone or do I have to buy all new lifters and pushrods? What else should I take note of? thanks, 641workmaster
Update: Yes they are avail. anywhere under $5 so now I'd just like to get it replaced today if possible.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
Yes, you can replace one lifter. It may or may not solve the problem, depending on the condition of the camshaft lobe it's riding on. You'll need to do a "break-in" run of 15-20 minutes at a fast idle of 2,000 TPM or so before idling the engine immediately after startup, the same way as is done with a new cam and lifter installation. This allows the new lifter to establish a running fit with the cam lobe.
Just loosen the rocker arm nut, remove the pushrod, swap lifters, and re-adjust the preload on the lifter. Then button everything up so the break-in run can be done before starting the engine.
Thanks Jerry! I ran across this post of yours on adjustment.
Quote
If there's a brass float in the carburetor, that backfire might have collapsed it. You might be experiencing a little flooding, resulting in the rough idle. Just a thought, as you've pretty well covered all the ignition-related problems. I believe all the 292's had hydraulic valve lifters, which require a pretty simple adjustment procedure. Each cylinder is brought to top dead center on the compression stroke, (engine stopped) the valve adjustment is loosened until the pushrod is sloppy, and then tightened to just remove the slack. Then tighten an additional 3/4 to 1 turn. (both valves). Turn the engine to TDC on the next cylinder in the firing order, and repeat until all cylinders have been adjusted. Don't try a running adjustment, it's sloppy and inaccurate!
What you've said is inline with someones description on the ChevyTalk forum.
Quote
Rotate the engine until the #1 exhaust valve has just started to open. Set the #1 intake valve.
Rotate the engine again till the next exhaust valve just opens (not the one on the cylinder next to the one you just set, but the next one that opens anywhere.) Set the intake adjacent to it. Continue to do this until all the intakes are set.
Now rotate the engine till the #1 intake valve is about to close. Set the adjacent exhaust valve. Again rotate until the next intake is about to close and set that exhaust. Continue until you have set all the exhausts.
Of course you don't have to start on #1, and on a V8 you can do one side then the other. Or if you want you can just work your way from front to back or any other order you choose. Just be sure you do all them. If you get lost, just rotate the engine till you see an exhaust open or intake close, and start setting again.
Most hydraulic lifters should be set 3/4 to 1 turn past initial contact, though some performance lifters call for 1/2 turn. That will put the lifter plunger in the correct position.
When you say the pushrod is sloppy do you mean it moves up and down? or rotates? Also you mention both valves. Does that mean intake and exhaust for the same piston? Just looking for some clarification between what you posted and this other individual. I think you may both be saying the same thing.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
I prefer getting the piston to top dead center on the compression stroke at once. If you search "companion cylinder valve adjustment" on this site, you'll probably find the procedure I recommend- - - -I've posted it several times and it's effective for both solid and hydraulic lifters. It involves getting the cylinder that's in between the exhaust and the intake stroke to the top of the cylinder by watching the valve action, and then adjusting both valves of the cylinder halfway around the firing order, as they will both be on the base circle of the camshaft at the top of the compression stroke. Using this method, all the valves in the engine can be adjusted accurately with only two turns of the crankshaft.
Loosen the adjuster until the pushrod can be moved up and down freely a little, maybe 1/8" or so, carefully take all the slack out, and then preload the lifter by turning the nut further. On the 194-292 series engines, 3/4 to 1 turn of the nut works well.
Thanks again Jerry. I found your technique outlined on the site and went by that. What I found was that most of the valves were a 1/4 to 7/8 turns tighter than they are now. I used the 3/4 turn method after the slack was taken up as outlined. Of course this is with the engine cold. Tomorrow I will run it for a good 20 minutes and redo the procedure. Kyle
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
On hydraulic lifters a hot re-adjustment really isn't necessary. There's enough range of motion of the lifter plunger to account for any growth of the pushrod and/or valve stem to make a hot adjustment a moot point.
Yeah I see that now. Just used to my 216's.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
Update. Pushed the truck out of the garage to start it and break in the new lifter. Upon start up, it sounds like a lot of clacking going on for just the guilty valve. Before it was quite quiet except for the offending one. I did not take the valve cover off to watch but just shut it right down to maybe make a 1/4 turn on all of them to make it a full 1 turn.
My only other thought of confusion may lie in the movement of the rod when I was adjusting for "slack". I interpreted it as just eliminating the free play up and down although the rod would still turn. That's how I adjusted. Now I am wondering if all play, up and down and rotating should be "just" eliminated? Thoughts?
I suppose I could have run it longer and it may have quieted down. Didn't want to damage anything.
Tonight will push it back in and make the adjustments, push it out, and watch with valve cover off.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
Riding in the Passing Lane
A new lifter needs a little running time to pump up with oil. It is hard to adjust it with a new lifter as there is little resistance after you take up the slack. Back it off & turn the adj. down till there is no play in the rocker. Then turn it down the additional 3/4 turn.
1972 Chevy c10 Cheyenne Super
I bench bleed new lifters in a container of clean oil to purge the air out of them. Submerge the lifter in a the oil and pump the plunger up and down with a Phillips screwdriver until the air bubbles quit coming out.
