0 members (),
348
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy lastchancetowing, unfortunately there are no foot starters for the V8s that I have ever seen. You will not be able to use the flywheel from the 261 on the V8, but with the correct flywheel you should be able to swap the clutch. Some of the 350 engines have a harmonic balancer that is too large to use the stock engine front mounts, the block mounts can be modified to clear this larger balancer or a hotrod tubular crossmember can be used to mount the engine using the engines block side mounts. Another kit that you might want to purchase is for the V8 throttle linkage. Also you may want to purchase a key start ignition switch, you could use the switch you have now and install a push button for the start function, hope that helps. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | Make sure your new V8 has short valve covers. Tall covers will not fit without modifying the firewall. The Rams Horn exhaust manifolds work well, there are no steering box conflicts when they are used. You will need a deep fan shroud or install an electric fan on the radiator. Mike B  | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy tclederman, That bellhousing should be fine, actually that looks like it has the small correct size opening for the throwout arm. | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Can someone provide the information about what flywheel to use ? A starter for that can I find hre no problems, a flywheel too. But it needs to fit the 261 clutch and the 350 engine.
This is going to be fun !!
I will keep the 261 engine for future use. My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy lastchancetowing, first we would need to know the size of the clutch your 261 has on it now, it would have to be one with 168? teeth (I can never remember the tooth count on the flywheels) | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Glad to know my brother inlaw has several flywheels from 350/400 engines, both 168 or is it 156 ? So I will be fine I hope  My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy lastchancetowing, 350 engines are internally balanced and 400 engines are externally balanced engines, so you must use a flywheel from a 350 engine on a 350. 400 engine flywheels have a weighted area on their backside so they are somewhat easy to identify, hope that helps. | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Here's something to watch out for as engine swaps may have happened over the years. Depending on the year model, many of the 1-ton and bigger trucks used a 10-3/4" clutch with a 9-bolt cover. The covers are no longer available and you'll have to have it rebuilt locally. You would not want to use one on a V8.
The clutch disc for both is the standard GM 10-spline but for the 6-cylinder the torsional springs are lighter than the V8. So you'll want to use a V8 disc. If by some chance, you have the 9-bolt cover, it will not work on the V8 flywheel unless you have the flywheel re-drilled. But then you'll have an obsolete clutch to deal with. So just use the V8 clutch. It'll mate with the SM420 trans just fine.
A 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Thanks Tommy, good to know. My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Just bought myself a good running 283 from 1966. Will pick it up tomorrow. Can I use this clutch and mate it with the SM420 ? https://www.summitracing.com/int/pa...e/chevrolet/model/c10-pickup?prefilter=1The bellhousing is: Chevrolet Truck Cast Iron Bellhousing, casting #: 3836923. My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | If you're looking for more torque, the 283 is going to disappoint you. That 3 inch stroke has to be kept in the high RPM ranges to develop the horsepower it's rated for and once the engine lugs down even a little, the performance suffers. The 350 has nearly half an inch more stroke and the difference is very noticeable. Jerry
| | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | I know, but I got it cheap.  My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
