5 members (UtahYork, Bucker, Buckeye998, Stovebolt48, Hotrod Lincoln), 152 guests, and 2 robots.
Topics128,190
Posts1,057,339
Members48,469
Getting ready to purchase a 1956 GMC NOS radio and speaker to go in my 1955 2nd Series Suburban Carryall, which is a 6 volt system.
Will one of those $69-99 Inverters make the Radio work ok?
Same for a 12 Volt Horn I just bought?
Thanks!
It depends on the amperage-draw of the radio.
It depends on the amperage-draw of the horn.
It depends on the amperage output of the converter/inverter.
Sir Searchalot
Sir Searchalot
Is your truck positive ground? If so, that is another factor. I would suggest that a TF truck should be 12V neg ground. Your future life will be much better and you will a cool guy. It's pretty easy to accomplish. A 6V TF truck is a mistake of nature.(and GMC). Putting in a bunch of resistors and transformers and voltage limiters and reducers and expensive gadgets is silly and will lead to bad teeth. We have a wonderful tip section on converting. Rewiring not required. BTW, I had a 56 GMC Carryall. Nicest looking truck I've had. Check out the "Solid Windows" tip for TF Carryall/Suburban....and this for Panels, Burbs and Carryalls: http://www.hotrod.com/how-to/wheels-tires/1402-spare-tire-mount/
Also from the experts in the "Radios" tip section is this:
Q. Can I use a 12V radio in my 6V truck?
Yes, if you can find a DC to DC converter to step the 6V up to 12, but it might be preferable to convert the truck electrical system to 12V.
Tks! So in Summary, convert to 12 volt system?
Love the spare tire idea.
I'll be using a 6v (positive ground) to 12v negative ground converter in my 1954 GMC COE - for radio and GPS and 12v charging of phone/etc.
Big Bolt Forum Moderator
I agree with Bartamos, 12v - ground is the way to go on your TF truck. I would not entertain the idea of trying to run a horn through a converter, a horn draws so much current, you would have to have one heck of a beefy converter! That may cost as much as converting to 12v!
Mike
Sir Searchalot
Sir Searchalot
Yes converting to Negative ground 12V is a good thing to do at this stage.
Thanks for the compliment on the article.
Riding in the Passing Lane
Those converters only handle about 2 amps. It's only good for a solid state radio.
1972 Chevy c10 Cheyenne Super
