4 members (treegrower, Otto Skorzeny, Shardean, 3B), 80 guests, and 2 robots.
Topics128,023
Posts1,055,365
Members48,420
#1159359 04/09/2016 2:07 PM
Bought a 1954 6500, trying to find the vin since the plate on door jam is missing. As per the registration I have 0899435344. I've tried the vin decoders but it's not coming up. Wheel base is 161 and frame might have been shortened. Thanks in advance.
Silenpro #1159407 04/09/2016 5:41 PM
look at the top part of the frame rail on the driver's side by the steering box, it might be there.
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Silenpro #1159414 04/09/2016 6:21 PM
Silenpro,
Welcome to Stovebolt.com
Good luck finding the Vehicle ID, if the metal tag is missing.
Hope for materman's suggestion to work out.
What is the Engine Serial Number, ESN (if you think it has the original engine). It is pressed into the block to the rear of the distributor.
There was no VIN in 1954 - sometimes/often the ESN was used for registration ID.
