| | | Forums66 Topics128,018 Posts1,055,339 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 22 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 22 | Bought a 1954 6500, trying to find the vin since the plate on door jam is missing. As per the registration I have 0899435344. I've tried the vin decoders but it's not coming up. Wheel base is 161 and frame might have been shortened. Thanks in advance. | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | look at the top part of the frame rail on the driver's side by the steering box, it might be there.
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Silenpro,
Welcome to Stovebolt.com
Good luck finding the Vehicle ID, if the metal tag is missing.
Hope for materman's suggestion to work out.
What is the Engine Serial Number, ESN (if you think it has the original engine). It is pressed into the block to the rear of the distributor.
There was no VIN in 1954 - sometimes/often the ESN was used for registration ID.
