4 members (dogdaddy, Ponchogl, 2-Ton, 1 invisible), 72 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
#115927 10/22/2003 1:28 AM
Junior Member
Junior Member
Howdy all..I have a question that needs answering. I am attemting to restore a 63 checy C-10. I need to sand and primer it. I have never sanded a vehicle. Do I use the auto sand paper as I use wood typr..meaning start with a lower number then work my way back up to the higher and finer grit?
I would appreciate any suggestions.
#115928 10/22/2003 2:40 AM
Welcome aboard p42.
Check out this site.
http://www.autobodystore.com/cgi-bin/archive1/config.pl
#115929 10/22/2003 6:49 AM
Click HERE for the Autobodystore forum.
You are on the right path. The smaller numbers are coarser. But you want to use automotive grade paper. And you want to buy it at an autopaint store. Buy the best you can possibly afford.
DO NOT buy the "retail" packed stuff at the "McParts" store like Kragen, PepBoys and the like. Go to the paint store that supplies the body shops in your area. If you don't know where it is ask a shop. But you want pro-quality paper, it is WELL worth the money and is actually cheaper than the retail packs you find at the McParts stores PER SHEET. It may be cheaper because you don't have to buy much at a time. But if you just break down and buy a 250 disc roll or a 50 sheet pack it is MUCH cheaper by the sheet. Believe me you WILL be using it. smile
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
