0 members (),
130
Mod | | | Forums66 Topics128,077 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 | Anyone have suggestions on how to cut out the floor shifter when installing a new floor mat? They have cut outs for everything except the shifter.
1942 BK 1/2 Ton Pickup 1954 3800 1 Ton Pickup
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | can you remove the shifter, put the mat down, and figure out where to cut it that way? If not, you may need to make a template out of butcher paper (or paper bags taped together) at least big enough to locate off some existing holes and then take the template out and mark your new mat. | | |
