2 members (R&S 51 GMC, Bill Hanlon), 90 guests, and 3 robots.
Topics128,125
Posts1,056,338
Members48,440
#1158884 04/06/2016 9:10 PM
Gents, can anyone advise if a carburetor for a 261 is the same as one for a 235?
Specifically, I have a 1960 235 and would like to possibly upgrade the carb to a slightly larger one. Can this be achieved by running a carb from a similar year 261? I've heard/read mixed reviews of the Langdon option, with some people saying its not a big enough carb for the 235.
I'm not looking to spend a ton of money, nor go to a dual carb set-up. More just looking for a semi-inexpensive solution that may provide a couple more hp on the stock manifolds.
Any input you can provide is greatly appreciated.
Kick it in the guts, Barry.
Riding in the Passing Lane
Yes. The 261 carb has a larger throat & venturi. It will perk up a 235. I had a 55 that had one on it a few years ago. You thought you were driving a V-8. They are hard to come by & have often been jugald around by "Remans".
1972 Chevy c10 Cheyenne Super
You will be trading off low speed and midrange performance for better full throttle. One of the effects of going to a carb with a larger venturi is a drop in velocity through the venturi and less, not more fuel is delivered due to the low velocity until the engine RPM is well into the cruising range. You will have to feather-foot the gas pedal to pull away from every stoplight to avoid bogging down and/or lean backfires. Top end will be better, however, but gas mileage will be terrible due to the power valve being open due to low manifold vacuum through most of the RPM range.
