8 members (Hotrod Lincoln, carbking, tclederman, Bill Hanlon, 49choptop, Guitplayer, John L., Otto Skorzeny), 125 guests, and 4 robots.
Topics128,042
Posts1,055,501
Members48,424
#115882 11/29/2001 7:07 AM
I am restoring my '56 GMC with the Pontiac V8.
I am trying to find the correct color and type of paint to use. It's red, but faded, any one painted one of these before?
1956 GMC 1 ton Napco 4WD
#115883 11/29/2001 3:52 PM
Lets see: a 56 GMC with a Pontiac V8, and you want to know the correct color. Now, I may be stupid, but I do not think that is the original engine, so why are you concerned with originality (as I interpret your word "correct")?
#115884 11/29/2001 4:04 PM
k10 Offline
GMC sourced its v8's from Pontiac in the 50's. GMC and Pontiac have been associated companies since the 30's and this still continues today. ( Just check out the dealerships; Chevy/olds soon to be dicontinued, caddy/Buick, GMC/pontiac) Until the GMC v6's came along, most of GMC's powerplants were Pontiac motors.
#115885 11/29/2001 5:42 PM
Brian, most people don't know that GMC used Pontiac engine for their V8s. '56 used the 316, '57 used a 347, and '58 and I think '58 used a 336. This is a fact. The engines all look the same in appearance, even a Pontiac 389. I have photos if you still don't believe me.
So far, no comments on the correct red color though...Dang.
#115886 11/29/2001 8:25 PM
A long shot would be top try the vintage Pontiac guys for old paint codes.
Like... http://www.boyleworks.com/ta400/psp/v8displace.html
Maybe this will lead ya on a "bread crumb trail" to your answer.
Luck
john
[ 11-29-2001: Message edited by: lil' johnny ]
#115887 11/29/2001 11:04 PM
You try my uncle, he rebuilds does hipo for Pontiac drag racers etc. www.sdperformance.com/
just type that in, and it'll bring you to his new page, look up the links, he know a lot of pontiac people and I'm sure you'd be able to get an answer quickly.
Nate
If you're clean, then you're not a 'Man' If your truck is clean, then your truck is a 'Queen'.
50 3/4T Chevy until it is traded or sold
48-55 1/2T Chevy parts until they're all gone
#115888 11/29/2001 11:26 PM
Gm used a red color on the 270. I just recently had my 270 repainted. If you can
be sure it's the same red and find no other leads I could get a number for the paint used on mine.
john
#115889 11/30/2001 12:05 AM
V
V Offline
GMC did, in fact, use Pontiac engines from 55-59. GMC was preparing to introduce the V-6 motor that they used from 60-68. They were expecting to hit a home run with this motor, and the pontiac motors were used as a stopgap until they were introduced. Unfortunately the V-6 never really caught on with the general public.
#115890 11/30/2001 1:12 AM
john123, I would be interested in the paint code for the color you used on your 270 GMC.. If you can post it here , I would appreciate it.. Thanks
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#115891 11/30/2001 1:36 AM
k10 Offline
Special Interest Autos (Hemmings pub) had an article on a gmc suburban with the Pont. V8. Can't remember if they had color pictures. (suburban = cameo in GMC speak)
#115892 11/30/2001 5:55 AM
napcogmc
There is a frame off restored 56 GMC here that has red 316 V8 it is a redcolor with just a little orange. Pontiac motor with GMC on the valve covers and hydromatic man I want it bad!
#115893 11/30/2001 5:17 PM
Thanks to all for the replies.
I sure didn't think this would be such a problem. I guess I am far too picky?...I could just have the paint color matched, but it is faded, plus haven't found anyone local CA that can do it using a high temp base.
I will do some following up on these few leads. Thanks again to you guys, a BIG thumbs up to you!
#115894 12/04/2001 1:37 AM
OK I was stupid to think that a pontiac engine would not be original. But maybe this can help if you still need information - try www.aaca.org, they have a bulletin board much like this one, those guys seem to know a lot about originality.
#115895 12/04/2001 5:46 AM
Brian - check the web site address you posted. That page "cannot be found".
john
#115896 12/05/2001 2:59 AM
k10 Offline
#115897 12/06/2001 12:59 AM
Thanks K10, I think sometimes I am an idiot, putting in a URL with a coma.
