| | | Forums66 Topics128,076 Posts1,055,922 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2000 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 67 | Has anyone used the spot weld cutters that Eastwood sells? They have two styles, one that is like a drill bit, and one that is like a small hole saw. Does one type work better than the other? How about durability?
Aaron | | | | | Joined: Dec 2001 Posts: 58 Member | | Member Joined: Dec 2001 Posts: 58 | I have both types in my tool box but I lean tward the solid drill style cutter. The hole saw type is a little tender but the drill can be wriggled around a bit to get it cutting without any trouble. Hole saws like flat surfaces, something seldom found on a spot welded panel. Just my two cents | | | | | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | I use the one that looks like a small hole saw. Works great providing: a sharp center punch is used in the middle of the spot weld to keep the tip from wandering and the surface must be flat. Uneven surfaces can cause the bit to wander, eliciting swear words. When the hole saw won't work, I will heat the spot weld with my torch and use an air chisel to separate. | | | | | Joined: Sep 2000 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 67 | Thanks guys. I was leaning towards the drill bit style one and it looks like that is probably the better way to go.
Aaron | | |
