| | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 59 | I had my 1953 3100 running and it sat for a while. I went to go start it the other day and the engine would crank but it wouldn't crank over. I figured the battery needed to get charged and put it on the charger. Now, when I put the battery back in the truck the volt gauge goes to 10 volts when the key is on. When I press the floor starter pedal the volts drop to 0 and the engine doesn't even crank. I have no idea what happened between taking the battery out to charge and trying to start it. Any help would be appreciated.
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | make sure your cables are clean and tight, not sure what you mean by saying it would crank but not crank over... I would think it would be normal for the voltage to drop when you are trying to crank, not sure how much.. I am sure some one will chime in and help out..........how long did it sat previous when ever thing was ok compared to now.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jul 2012 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 59 | The engine would crank and crank but it wouldn't start. The weird thing is that the voltage just drops and stays at 0 after I hit the floor starter pedal. I tried another battery out of my daily driver and it did the same thing.
| | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | Hi, bert, I have the same problem up here on the wet (west) coast of Canada. What happens is when the truck is turned off the points are open and they oxidise. You need to clean the points with a point file or use about 600 grit wet and dry sandpaper used wet with contact cleaner (can also use brake clean, acetone etc.)
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Clean and tighten the battery cable terminals. Works every time. The inside of at least one of the the terminals has enough corrosion to kill the current flow as soon as a little load goes on the connection. Jerry
| | | | | Joined: Jul 2012 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 59 | Thanks everyone. I'll give that a try tomorrow. | | |
