| | | Forums66 Topics128,049 Posts1,055,675 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 41 | .030 is the most you can go for crankshaft journals main or tod right? By the way I found block to replace my cracked one. But it is bored over.060 | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | A 60 overbore on a block isn't wonderful, but stovebolt engines have enough cylinder wall thickness to function with 60 or even 80 thousandths oversize cylinders. The main problem with a big bore block is it limits how many more overhauls the engine can tolerate. Since most of the oldtimers we deal with aren't going to be daily drivers, using a big bore block isn't as much of a concern as it might have been 40 years ago. Just be sure the cooling system and the engine's water jacket is very clean, as big overbores are a little more prone to running hot due to thinner cylinder walls. Jerry
| | | | | Joined: Jul 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 41 | But .030 is the most you can go right so if you have one already. You would have to find a replacement. For crankshaft journals | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Or they can build up the journals and grind back to stock or any other size you select. | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Actually, my Federal-Mogul master bearing specification catalog lists stovebolt main bearings down to .060" undersize and rod bearings to 40 under. It's not the smartest thing to do, but the parts do exist. Welding and regrinding a single journal is OK, but trying to build up all the rod or main journals results in lots of warp and the need to do some serious straightening. Even big, expensive cranks like a Cummins diesel seldom got welded and reground on more than one or two journals, at least in the machine shops where I've worked. Passenger car and light truck shafts, no way! Jerry
| | | | | Joined: May 2015 Posts: 11,031 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,031 | Ford has a process that they use on their PowerStroke diesel rebuilds to build up cylinder walls so they're back to standard. There may be a similar process (known as metallizing) for crankshafts, but it has to be expensive. That's the driver for whether it's done much. For large engines where you'd have to wait months for the manufacturer to build you a replacement crank, that would be the way to go. As far as cylinder oversize, I've seen Model A engines bored 100 over. I think you could even find 125 over pistons back in the day. But the Model A's had pretty thick cylinder walls. Modern engines won't stand nearly as much boring. Not sure where a stovebolt lands in that respect, old time or modern. I kind of classify anything with overhead valves as modern.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | I'm in the process of building up a Model A engine with MOPAR 360 V8 4" pistons, which is a .125" overbore. They're a surprisingly close fit, only requiring a smaller wrist pin bushing in the connecting rods to adapt for the smaller-diameter piston pins. The compression height of the pistons is almost exactly the same as the Model A parts. I'm also tinkering with an aluminum insert for the combustion chambers, held into place with an anchor bolt through the spark plug holes, to increase the compression ratio. Just like in the song "Hotrod Lincoln"- - -"A kid in a hopped-up Model A!" Jerry
| | | | | Joined: Jul 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 41 | I have noticed from the old block 3837004 to the new,one 3836233. The 7004 had a oil passage through the lifter bores and the 6233 does not. I never knew there was a difference. Anyone have a explanation | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | The block with the oil passageway front to rear through the lifter bores is set up for hydraulic lifters. It can be run either way, solid or hydraulic, while the block without the oil passage is solid lifter only- - - -no way to supply the oil that keeps the lifters pumped up. Jerry
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Quick Digression Boys - Jerry, think you need to start a journal of your Model A project so we can follow along. OK, it's not a stovebolt, but the HiPo crowd can learn a lot, maybe we can make an exception? Here's a goal for you. Next week is the Lone Star Roundup in Austin, Tx. I'll be there, with several hundred other Model A's, and about 2000 Hot Rods +/-. So in a year or 3, suggest you drive your Model A to the Lone Star Roundup.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | I'm building this one for an in-law who has a very nice older restoration of a 1930 rumble seat coupe. It's going to be a slightly hot-rodded backup engine with insert rod and main bearings, an overbore, and a high compression head. Stovebolts aren't my only interest- - - -I like Furds, too! Jerry
| | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Cranks are sent out to specialist and the Typical quality production crankshaft rebuilder will:
Thermal cleaned Steel shot blasted Boltholes and keyways inspected Worn journals are restored Bearing journal surfaces are machined, polished Oil holes chamfered and deburred Oil line passages cleaned and rust inhibitor applied Crankshafts are packed and covered with two-mil poly film and encapsulated with sprayed foam Main and Rod Bearings are included | | |
