4 members (Jon G, 5 Window 9434, Charles in CA, dt235sd), 54 guests, and 0 robots.
Topics128,049
Posts1,055,635
#115798 04/20/2003 6:56 PM
Need some advice, Frame is blasted and Im getting ready to paint. It will mostly be a show truck so I want the frame to match the body. So here are the questions.
1. Should i bondo the low spots before I prime?
2. What primer? Will I need to us an etching primer then a filling primer?
3. What paint?
I am looking at the House of Color Sunset Pearl, kind of an orangey gold color. Suspension parts will all be powder coated black. THANKS
#115799 04/20/2003 10:53 PM
How deep are these "low spots" you are talking about? Are they pits from rust or just stamping marks or what? If they are not deep (say, about a 1/16") you could just prime it with polyester primer to fill them. This is much easier than spreading plastic filler and sanding. But, if they are a little deeper, you could fill them with the body filler THEN polyester prime to fill the smaller things and sand to perfection. The etch can be sprayed after body filler, it depends on the brand you are using and the part number.
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#115800 04/21/2003 12:33 AM
some spots are going to need a little filler. I havent picked a brand yet, but would like your recommendation on which to use and part #'s if ya got em.
Also if I etch prime will I need another primer over it before I paint?
#115801 04/22/2003 7:04 AM
If you're going to spending the time and money to shoot the HOK you will want to have urethane primer on everything. The etch can go down first and then urethane over that. First do the plastic filler work and then shoot the etch, as long as the brand you use has recommendations for that. Then sand the urethane and shoot the color just like you would on the top of the truck.
If you plan on using HOK paint, just go with HOK primers.
1948 Chevy Pickup
#115802 04/22/2003 5:41 PM
THANKS MARTINSR. Im sure I will have additional questions in the future. Its nice to be able to get reliable info from someone. Half the staff at the local paint supply has no idea and just recommends the same products to everybody for every situation.
#115803 04/22/2003 9:29 PM
You have to be carefull using filler on the frame because it tends to flex. If the holes are too deep you should weld them first
Paint & Body Shop moderator
#115804 04/22/2003 10:50 PM
they are not to deep and after all the work of boxing it I just cant see painting over the depressions.
#115805 04/23/2003 12:46 AM
Junior Member
Junior Member
Hey MARTINSR!
Your on this forum too? cool I see you frequently on the Team Chevelle Forum over at chevelles.com. My user name is Malibu Man. Just wanted to say hi!
#115806 04/23/2003 1:20 AM
Josiah, I have to disagree with you on the flexing of the frame. There is no way, not even close, that the flex of a frame is going to cause any problems. The long gentle flex isn't even close to the short confined flex of a door for instance. If you have seen a failure it was not do to the frame it's self but to application. If plastic filler is applied correctly it will out last both you and I!
Trever, how are you doing? You have some old trucks too, cool. smile
1948 Chevy Pickup
#115807 04/23/2003 9:15 PM
Maybe you are right, the failure I saw was on a Jeep CJ frame and it wasn't mine.
