0 members (),
106
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2016 Posts: 15 New Guy | | New Guy Joined: Feb 2016 Posts: 15 | Hey all, I decided against a V8 swap and want to rebuild my 292 with more performance, seems cooler to me...I would like to try and squeeze 250+ hp out of it, and would like to do as much on my own as I can. *BUT* this is my first inline build so I'm looking for any info on weak spots of the 292, engine recipes, any sort of "don't ever do this" or "definitely do this" info you pro's might have for a new guy. I've done a little research and am pretty certain I'm going to send my head to the www.12bolt.com guys for some work, what work exactly I still don't know haha...but any info will help thanks.
Question 2: has anyone put a Muncie or Saginaw 4 speed behind their inline before? Just wondering how complicated it is. Thanks | | | | | Joined: Feb 2015 Posts: 273 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 273 | There is a book everyone always brings up when this is asked, but the title escapes me. I'll see if I have it saved somewhere. In the meantime, someone else may come up with it.
Larry W.
1953 3800 Dually Flatbed
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | squeeze 250+ hp out of it It can be done, but it's expensive. There's no practical way to increase engine size, and you can only raise compression until it won't run on pump gas. This leaves 2 avenues of approach: higher efficiency (porting, cam, valve size) and higher RPM. It's also not the same 250 hp you would get from a mild 350 - it will have less low and mid-range power, and only produce peak power at higher RPM.
It does make a pretty good turbo project if you can fabricate. | | | | | Joined: Feb 2016 Posts: 15 New Guy | | New Guy Joined: Feb 2016 Posts: 15 | Ok great, thanks, I had seen some stuff about that book in some of my searches, but I typically like the advice of guys who have actually done the work but this book must check out if I've seen it so much...thanks!! | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Look for propane Pistons to start with.
Ed
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | | | | | | Joined: Feb 2016 Posts: 15 New Guy | | New Guy Joined: Feb 2016 Posts: 15 | Look for propane Pistons to start with.
Ed Propane Pistons? Honesty moment here, I have never heard of that on gas engines haha. Is it similar to propane injection on a diesel? I have a couple crazy diesel friends that were big on that for a while but I still don't really know anything about it | | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | Propane or LPG pistons have a smaller dish/recess to give a higher compression ratio.
SimS | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Honesty moment here, I have never heard of that on gas engines haha. Stick around- - - - -you might actually learn something if you drop the attitude case. Ed has probably forgotten more about stovebolt engines in general than you will be able to learn in the next year or two. Most industrial engines like the 292 Chevy and the Ford 300 6 cylinder have optional parts available for offroad applications, and Propane-fueled engines are used a lot for irrigation pumps, generators, and farm equipment. Since Propane is approximately 110 octane, compression ratios in the 11:1 range are not uncommon on engines running on straight Propane, not in a dual-fuel capacity. When I was in charge of the maintenance shop for a sand, gravel, and concrete producer, virtually every spark-ignition engine we had ran on Propane, and most of them were set up for high compression. Jerry
