0 members (),
94
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 53 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 53 | May have located a pretty good set of doors from a 47-49 pickup. Can I use these on my 51? Do the vent window frames just bolt in or are the doors a lot different?
53 Dumpy
1951 Chevy 3100 "Ernestine" 1970 Chevrolet C10 "Ol' Blue" 1940 JD "long-hood" B 1959 Jeep FC-170 1960 IH B275 2013 Chevy Silverado 2023 GMC Denali 2500HD
| | | | | Joined: Mar 2003 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2003 Posts: 68 | 51 was the first year that used vent windows. You may be able to fit the frames in but then there is the question of the window tracks. Im sure others more qualified than me can answer this one. | | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | You'd have to cut open the door and fabricate a brace for the wingvent assembly to bolt onto, then trim away portions of the door skins and the top of the doorframe to create a notch for the assembly to fit into. This could be extra tricky if the window regulator in in the way. You'd still need to find 51-later surrounding trim to cover the hacking scars. Then you need to figure out how the thing is going to latch, as the early turn-down handles won't meet up with the later latches correctly.
In other words, you'd be better off either finding later doors or forgetting the vent windows and just modifying the latch. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Actually, '51s were the only year with the vent windows and the drop-down door handles. As far as I know, the push-button handles were introduced in '52. | | |
