2 members (Bill Hanlon, Rich'sToys), 82 guests, and 2 robots.
Topics128,127
Posts1,056,678
Members48,452
#115780 01/16/2004 9:11 PM
May have located a pretty good set of doors from a 47-49 pickup. Can I use these on my 51? Do the vent window frames just bolt in or are the doors a lot different?
53 Dumpy
1951 Chevy 3100 "Ernestine"
1970 Chevrolet C10 "Ol' Blue"
1940 JD "long-hood" B
1959 Jeep FC-170
1960 IH B275
2013 Chevy Silverado
2023 GMC Denali 2500HD
#115781 01/16/2004 9:29 PM
51 was the first year that used vent windows. You may be able to fit the frames in but then there is the question of the window tracks. Im sure others more qualified than me can answer this one.
1953 Chevy 3100
The Green Truck
#115782 01/17/2004 1:10 AM
You'd have to cut open the door and fabricate a brace for the wingvent assembly to bolt onto, then trim away portions of the door skins and the top of the doorframe to create a notch for the assembly to fit into. This could be extra tricky if the window regulator in in the way. You'd still need to find 51-later surrounding trim to cover the hacking scars. Then you need to figure out how the thing is going to latch, as the early turn-down handles won't meet up with the later latches correctly.
In other words, you'd be better off either finding later doors or forgetting the vent windows and just modifying the latch.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#115783 01/17/2004 9:01 AM
Actually, '51s were the only year with the vent windows and the drop-down door handles. As far as I know, the push-button handles were introduced in '52.
1954 GMC De Luxe COE
