1 members (Hotrod Lincoln), 75 guests, and 3 robots.
Topics128,090
Posts1,056,376
Members48,442
#1157499 03/29/2016 8:12 PM
1 Offline
So, I have a 1954 3800. The inside, with exception to the door uppers, is a tan/beige color. I need a new headliner which is also that same tan color. The closest I could find was medium brown but when I just received it from Jim Carter it is REALLY brown. I haven't found any others that may fit. Has anyone else found this to be a problem? Do I need to accept my headliner will be brown?
1942 BK 1/2 Ton Pickup
1954 3800 1 Ton Pickup
I think JC is, as usual, correct (for standard 1954 cab interior color - Pearl Beige).
However, this sales brochure shows a headliner that matches the interior color?
(sales brochure are often done by artists, not by photographs)
Deluxe interior (Pulsar Gray, with light Gray headliner) and two-tone interiors had other colors (none of them light tan).
Chevs of the 40s also sells black, brown, and gray.
Classic Parts - black, brown, and gray (and 2-tone interior).
You could paint the headliner whatever color suits you.
I suggest painting/sealing the top/edges of the cardboard headliner to diminish warpage from moisture.
1 Offline
Well, Since the seat is brown, and the door trims (I guess that's what you call them, just below the window) I don't think the brown headliner would be too bad. Who know's maybe the original owner before me painted it over time.
Anyway, thanks for the help (again)!
I think that brown would look good.
Consider my advice to seal the top and edges of the cardboard headliner.
Humidity/condensation will quickly deform the cardboard.
Tim,
Quote
Can you add more detail as to how?
Harold
Harold
Harold,
Do you use any 2-part urethane? - spray the cardboard panel with good side down (try to get a good seal on the edges )
Maybe people will recommend a brush-on or spray-can paint that will seal cardboard from moisture?
Tim,
Do you think the Spray Can "Clear" would work?
Harold
Harold
I am paint "illiterate/ignorant". Maybe someone with knowledge/experience will reply?
You might want to check the product description on-line. It might give information about moisture resistance.
Good luck.
Moderated by  ndkid275, Phak1
