4 members (50Chevy3100, Otto Skorzeny, carbking, 1 invisible), 74 guests, and 2 robots.
Topics128,023
Posts1,055,370
Members48,420
#1155261 03/16/2016 3:17 AM
1958 GMC 1/2ton truck w 3 on the tree. Thinking about moving the shifter to the floor. What are you using?
Thanks in advance
Danny
1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
dtwbcs #1155267 03/16/2016 3:21 AM
Its a 3speed trans with manual OD
Danny
dtwbcs #1155280 03/16/2016 5:10 AM
The only floor shifter I know of that will work with an SM319 overdrive is the one Deve designed.
dtwbcs #1155310 03/16/2016 2:40 PM
Deve is awesome on so many different levels. It is a great site just to visit and learn.
don
dtwbcs #1155518 03/17/2016 11:51 PM
I noticed that is for the 47-55 truck design. Will this work with my 58?
Danny
dtwbcs #1155653 03/18/2016 9:25 PM
What about the one that Patricks' sells?
Danny
dtwbcs #1155674 03/18/2016 10:55 PM
Probably not. The shift arms are different.
The question to ask Patrick is 'will this mount on a transmission with an electric solenoid on the side?'
dtwbcs #1155680 03/19/2016 12:07 AM
ok, thankyou
Danny
dtwbcs #1157322 03/28/2016 10:29 PM
Patricks said -Nope ; but call Lockar . Maybe somebody has modified one to fit?
Danny
dtwbcs #1157465 03/29/2016 4:36 PM
Someone made them, probably Hurst but they are likely scarce.
I rebuilt an OD for a guy with a 65 truck. It had a shifter that was installed by the PO so he didn't know anything about it. However, it mounted higher up on the housing than the conventional 3 speed shifter and the arms cleared the solenoid. There may be a larger space between the floorboards and the trans on a 60's truck than yours so if you find one it still may not work. Deve's truck has the same transmission that you have but he has built the shifter to accommodate his vehicle.
I see no reason why it wouldn't work for other series vehicles.
Fred
dtwbcs #1157584 03/30/2016 3:53 AM
Understanding that they are scarce. Was thinking of modifying a hurst shifter.
Danny
dtwbcs #1158047 04/02/2016 4:45 AM
running into another dead end...
Danny
dtwbcs #1158164 04/02/2016 10:11 PM
Hurst made a shifter for the overdrive. It was a mystery shifter, M/S-CV-5863-OD. Made by Hurst-campbell, inc., Warminster, pennsylvania. 1962
Tommy
59 apache 1/2t
261 short stepside
dtwbcs #1158169 04/02/2016 11:10 PM
Danny
