2 members (Guitplayer, MickeyP),
70
Mod | | | Forums66 Topics128,021 Posts1,055,356 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | 1958 GMC 1/2ton truck w 3 on the tree. Thinking about moving the shifter to the floor. What are you using?
Thanks in advance
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Its a 3speed trans with manual OD
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The only floor shifter I know of that will work with an SM319 overdrive is the one Deve designed. | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Deve is awesome on so many different levels. It is a great site just to visit and learn. don | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | I noticed that is for the 47-55 truck design. Will this work with my 58?
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | What about the one that Patricks' sells?
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I noticed that is for the 47-55 truck design. Will this work with my 58? Probably not. The shift arms are different. What about the one that Patricks' sells? The question to ask Patrick is 'will this mount on a transmission with an electric solenoid on the side?' | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 |
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Patricks said -Nope ; but call Lockar . Maybe somebody has modified one to fit?
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Someone made them, probably Hurst but they are likely scarce. I rebuilt an OD for a guy with a 65 truck. It had a shifter that was installed by the PO so he didn't know anything about it. However, it mounted higher up on the housing than the conventional 3 speed shifter and the arms cleared the solenoid. There may be a larger space between the floorboards and the trans on a 60's truck than yours so if you find one it still may not work. Deve's truck has the same transmission that you have but he has built the shifter to accommodate his vehicle. I see no reason why it wouldn't work for other series vehicles. Fred
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Understanding that they are scarce. Was thinking of modifying a hurst shifter.
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | running into another dead end...
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Hurst made a shifter for the overdrive. It was a mystery shifter, M/S-CV-5863-OD. Made by Hurst-campbell, inc., Warminster, pennsylvania. 1962
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 |
