0 members (), 135 guests, and 3 robots.
Topics128,089
Posts1,056,440
Members48,443
#1156571 03/24/2016 1:32 AM
Big Bolt Forum Moderator
I have both a 55 and 58 2-ton. Does anyone know for sure if the brake hoses (need to replace both front and rear) are the same on these 2 trucks? Napa shows them for the 58 but not the 55. (model 6400 on both trucks)
Mike
My Parts Book shows the following;
55/56 Ser 4-5-6 (exc. H.D.)....Front (7-1/16-20 ext.-7/16-24 int.- 17-1/8 long....714267
55-59 Ser 4-6 (exc H.D.)....Rear (7-1/16-20 ext.-7/16-24 int.- 16-25/32 length....476719
58-59 Ser 4-5-6 (exc. 6D, 6V, 6E, H.D. Frt axle)....Front (18-31/64 O.L.-1/8 I.D.)(daub of white paint (5/8-18 ext - 7/16-24 int)....3748878
Hope this helps,
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks, Mike! I found a set on Ebay for a 55/56 and they told me it was the same as for my 58... What I found on Napa did not jive with that though! You have confirmed what I thought! Now to see if I can find some local somewhere cheaper than Napa! I'm going to call Brake and Clutch in Seattle tomorrow, I am having a hard time spending almost 45 each for the fronts from Napa!
Mike
3B Offline
Hy 69Cuda, according to the Raybestos online catalogue the 55 6400 uses BH4497 for the rear 16 7/8" long, for the front it uses BH4900 17.69" long. For the 58 it lists the same rear BH4497, but for the front it lists two possibilities BH25664 20" long, or BH36548 18 9/16". personally I would order the lines for the 55 and see if they will fit on the 58 as well, the lines can be ordered through RockAuto or I'm sure Napa could cross those part numbers, hope that helps.
Thanks, Napa's online info says for 58, the 4497 is for if it as a 3/4 or 1 ton chassis. They list the 4000 for the 2 ton. Difference is 3" longer and the one end is threaded for a nut instead of having slots for a keeper. I think I'll crawl under both mine tomorrow and see if the shorter one will work on the rear as well as see if the 1" shorter ones will work on the front! Napa has the 4900 for 11.43 instead of almost 46 for the other one! Same with the front numbers you gave me, the 25664 is 13 instead of 46!
Mike
I'll be interested in your findings as well. My 55.2 6400 already has new lines in the front, but the rear rubber line looks pretty old, cracked, and crusty. I ought to replace it before I even try to fill the brake system with fluid.
online pictures of the ends for the UP4497 at Napa looks like it is what is on my 55.2. It is 11.49
Mike
Paul,
If it was me I'd replace ALL of the lines (steel and rubber) on your Frank'n truck, they fail from the inside out and you only have one circuit. It's easy to do and doesn't cost that much. No sense taking chances...do it now and forget it for years to come.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
OK, Looking at both my 55.2 and 58, (both 6400 models) the rear hose on the 55.2 is the BH4497 (or Napa UP4497) and is on the passenger side. The rear hose on my 58 is on the driver side and is the BH4000 (or Napa UP4000). The 4000 is longer and the frame end has external threads for a nut instead of slots for a keeper.
Mike
Mike B smile
That was my original intent, but like I said, some of them are new. I was downright surprised, but they must've been replaced right when they quit using the truck. They don't even have a spec of dirt on them. I will be sourcing some tube and nuts for the steel portions though. Many of them look like they'll strip out as soon as I start messing with them anyway. The tow truck driver actually asked me if he could just wrap around the rear axle with his chain, and I told him to go right ahead and crush the lines, and I didn't intend to use them.
I just gotta figure out where all the fluid went. Since there are new lines up front, I'm suspecting the troubled braking system may have been what caused this truck to be parked long-term.
So is Napa a good place to get bulk brake line tubing? The other parts stores don't seem to know the difference between metric and standard tubing nuts...
looks like Napa has 25' rolls of tubing, that is on my list to go get this week. My dad bought some from Summit for his 40 Chevy car, he said it came with nuts. Looks like they are a lot cheaper than Napa....
Mike
I'm seeing it on Amazon too. It looks like there's a copper/nickel alloy and a zinc plated steel version commonly available. The steel looks cheaper and I'd imagine more durable, though probably harder to work with and more corrosion prone. Let me know what you go with. My flaring kit is cheap, but has worked fine for copper tubing in the past. I'm not sure how well steel would work out, so I may lean toward the copper/nickel.
After a little reading, I think I'll spend the extra ten bucks on the copper/nickel.
http://www.copper.org/applications/automotive/brake-tube/brake.html
CU-NI (NI-CU, NiCopp)
Check NAPA and other local auto-parts suppliers. I also got it at a good price at Autozone and Advance Auto (15-20% off on-line).
this is what I bought (regular steel). http://www.ebay.com/itm/STEEL-BRAKE-LINE-TUBING-KIT-3-16-25-FT-15-3-8-24-SAE-BRAKE-LINE-FITTINGS/321961612810?_trksid=p2060778.c100275.m3474&_trkparms=ao%3D1%26asc%3D35608%26meid%3D6f5787e896a94fe1a9308b7cc128c97f%26pid%3D100275%26
My dad has a very expensive flaring tool kit so, I am not worried about getting soft tubing to work with.
EDIT - I bought 3/16 tubing by mistake! should have bought 1/4" DOH!
Mike
pvfjr,
If you didn't replace the brake lines on your truck you are just guessing how new or old they are. Steel lines fail from the inside out, why take chances. While you have all the tools out why not replace EVERYTHING at the same time and be done knowing it's all done right and new.
My .02 cents.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
