1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | I know this really isn't electric but.. decided to replace my old odometer on my 53 1/2. Got new one from JIm Carter. Taken old one out and not sure how to set the new one at the previouis milage. Did not look closely enough at the old to see how the five tabs separating the wheels line up. Any one familiar with this ? Thanks, Scott | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | All the tabs face down ...pic... They ride in the cradel at the bottom | | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | Will call. What are your thoughts...new rebuilt engine, cash deal. Was going to set odometer at 00000 instead of 43320 on title - though old odometer has not worked since I bought truck 7 years ago. Would this be a problem if I ever sell? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Is the truck titled by engine number? | | | | | Joined: Dec 2002 Posts: 3,437 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,437 | Most titles (that I've seen/dealt with) have a mileage disclaimer.
it's usually:
Actual, exceeds odometer capability (rolled over) or not actual (or words to that effect).
| | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | Truck title in original milage. Odometer has not worked. Put new rebuilt 235 in it so wanted to set odometer to 0000. | | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | When placing the new number spool in the housing how do you lineed up the numberstairs that you want? Once it is in place is it possible to force turn the wheel to get the correct numbers? Thanks, Scott | | |
