1 members (2-Ton), 68 guests, and 2 robots.
Topics128,214
Posts1,057,488
Members48,473
I'm continuing work on my Suburban (1950) by patching and cutting.
I have a question about the lower rear valence area that bolts onto the lower left and right rear corners. There are a couple captured nuts on the inside of these two out and lower corners.
Does someone have a picture of this area and the part that bolts to each corner below the tailgate area?
Seems like I am missing this piece.
Related: I see that Jim Carter's catalog has parts for this area (SM574, and SM575) but I am not sure where these are located and wondering if these are the sheet metal parts I need. (?)
Thank in advance. Tom
my email is: [email protected]
1946 GMC Project
"Back-in-the-day Restore"
Those JC parts are for above the rear valance (stone shield?).
I do not like to try to search JCs site, but here are the lower rear panel-body repair pieces:
left
right
OK - I found them on JC's site:
JC left?
JC right?
JC's parts seem to include the captive nuts needed to attach the hangers for the rear-valance/rear-stone-shield
Thanks, Tim. This helps. Looks like I need to find or fabricate two end brackets for the stone shield. And if I understand correctly the brackets bolt to the inside of the lower rear corners using the captured nuts.
Thanks again. Tom
1946 GMC Project
Tom,
Two brackets at lower rear corners, and I think two brackets equi-distant underneath the rear valance/stone-shield.
I am not near my Suburban, or I would offer to take pictures. Maybe someone will do that for you?
Good luck,
Tom, I can take the pics you need. Let me know.
My 49 should be the same.
Weeds
Thanks! I am in need of a photo or two of the brackets that attach to the lower rear corners and the rear gravel shield. Found a NOS gravel shield not long ago but missing the brackets.. Not sure what they look like and where to find them. Thanks, Weeds. PM sent.
tom
1946 GMC Project
Wow, talking about finding a needle in a haystack! Thank you so much for posting a source for those rear corner patch panels! You are a true life saver. Thanks again, kyron
Just went to dmv yesterday to register my 53 suburban and only had the serial number on door jamb. Turns out my 53 is really a 52! There isn't any difference between the two years is there?
1953 changes from 1952 (most info from JC):
Door post ID plate is now blue & silver. Prior years were black & silver
Hood front emblem now stainless steel
Series/model emblem on sides of hood changed (same as 1954)
1951 3100 Chevrolet
THANK YOU for posting these photos. This is just what I needed to see. I can now look for the corner brackets seeing that I now know what they look like. Thanks for taking the time to post these pictures. They are a big help. tom
1946 GMC Project
1951 3100 Chevrolet
If any one has a lead on NOS brackets or a valance I'd really appreciate it. Thanks for posting these pictures as I also needed the information. Living in the rust belt makes life difficult!
Still trying to get ole Betsy back on the road.
Might try Ray Stanley over on Oldgmctrucks.com. He's restored/rebuilt a few valances. Not sure what his turn around/work load is like but his work is top notch!
1955.1 GMC Suburban Hydramatic
Ray did not make a 47-55 panel-body rear valance several years ago - please let us know if he now makes one.
http://www.wheelwrightrestorations.host-ed.me/
http://www.oldgmctrucks.com/page0215.html
Ray Stanley
Wheelwright Restorations
92 Pine Street Wheelwright, MA 01904
1-413-477-6467
thanks! I found one good corner bracket in the box of parts that came with the truck -and the other corner bracket broke in half. I guess I could weld the broken bracket and use it - not ideal - but its not a piece that sits in plain view either. Or attempt to make a new one...shouldn't be too complicated. thanks to all for the help. Very much appreciated.
tom
1946 GMC Project
