2 members (Ole49GMC, Hush), 74 guests, and 3 robots.
Topics128,169
Posts1,057,102
Members48,463
Looking to change out front suspension on my '50 Chevy truck. Can anyone recommend what front clip I could look for to replace existing front clip? Thanks,
Several years I did one using a 72 Nova subframe. I had a weld shop do the install and if you didn't know what you were for it was hard to tell where he made the splice.
For with God nothing shall be impossible. (Luke 1:37)
http://s224.photobucket.com/user/72cj351/library/48-52?sort=2&page=1
Paul
I have installed a mustang ii front end in my 1953 pickup and bought another for my burb. I like the set from gearheadworld great guys and parts
Thanks guys for the responses. I will check both of these out. "preciate it.
My truck was built in the mid-80's when crafting a subframe was the thing to do. This was before the after market M2 style kits.It handles very well. If you are a good Fabricator and on a budget A Nova or Camaro sub,may be the way to go.
I am looking at changing out the rear suspension on my '50 chevy truck and wondering if a 1990 Chevrolet truck rear end would work? Does anyone have any thoughts? Thanks,
Can anyone tell me if a 2002 Camaro Z28 front suspension would work on my 1950 Chevy truck? mThanks
Q #1 -- There are a lot more compatible rear ends to choose from.
Q #2 -- Not without a lot of heavy duty fabrication.
I've had a couple of different suspensions. The first one was from a 79 C10 that that I narrowed and bolted onto the frame. I used a set of dropped spindles and cut a coil and a half to bring the nose down. I went this route because it was relatively inexpensive, got the ifs for free, cost me $60"to narrow the crossmember & center link. I drove it for a couple of years but decided I wanted to lower it a bit more & run larger tires so I opted for the bolt on mustang ii. Just finished the swap last week. Love the stance & the ride is even better.
Robert C.
I'm a Genius in the making.
1950 3600
Question about the rear end. The limiting factor is width. It seems 57-60 inches is about right.Wheels with 4 3/4 back spacing.
