1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11567 08/28/2002 11:30 PM | Joined: Mar 2002 Posts: 30 Junior Member | | Junior Member Joined: Mar 2002 Posts: 30 | While searching for a replacement 292 I came across these two vehicles, vin #KC6535B119986 and #OC633N10890, both are early 60's model C60 Chevys. One has a 292 and the other has an inline 6 much larger than the 292. Is it possible Chevy used a GMC 302? Or, is there a larger inline Chevy than the 292? I checked American classics for vin #'s but they only cover the 1/2 ton trucks. I have digital photos of the engine but I can't figure out how to post them. Thanks for the help | | |
#11568 08/29/2002 5:31 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Only way to post here is to use one of the free hosting services or send them to Joy. For your engine id, if you go to Inliners.org and go their casting number section you should be able to id your engines. Casting number on older Chevy sixes are above the starter, I don't know about the GMC or newer chevy six.
Fred 52 3600 69 C-10
#11569 08/29/2002 12:35 PM | Joined: Feb 2002 Posts: 5 Member | | Member Joined: Feb 2002 Posts: 5 | If in fact you have a GMC engine the CID is stamped on the distributor ledge
Ronnie
Rember to keep it INLINE!
