3 members (Bucker, 3B, Snowman51),
94
0
Mod | | | Forums66 Topics128,157 Posts1,056,893 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 115 'Bolter | | 'Bolter Joined: May 2001 Posts: 115 | I am going to have the wheels on my '40 powdercoated. I just got new tires so now is the time to do it. What should I expect to pay per wheel?
Brian D
| | | | | Joined: Jul 2002 Posts: 166 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 166 | I had 5 new rims made & powdercoated for my 52 MGTD at Stockton Wheel. The cost for powdercoating was $55.00 per wheel. The wheels turned out very nice and was worth the money. | | | | | Joined: May 2001 Posts: 115 'Bolter | | 'Bolter Joined: May 2001 Posts: 115 | Charles, That is about what I was expecting. By the way I too have a '52 mgtd. It is unrestored with 62k original miles. I needs paint but is a good driver.
Brian D
| | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Had my 55.1 16" wheels blasted and powder coated for $20 each at Pomps. - Scott
55 1st Chev.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Can you fill pits and still PC ? | | | | | Joined: Jul 2002 Posts: 166 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 166 | Brian, I forgot to mention the powdercoating included blasting the centers & new outer rims prior to coating. My TD was restored 10 yrs ago, drives great!! Charles | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | MetalMan - no, that's the drawback of powdercoating - it's bare clean metal only Bill | | | | | Joined: Jul 2003 Posts: 179 Member | | Member Joined: Jul 2003 Posts: 179 | Another drawback - if and when it chips you can't just touch it up......albeit - it is much harder to chip than paint.
- Ryan
59 Apache Step 78 El Camino http://www.wsu.edu/~rsain
| | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Originally posted by squeeze: MetalMan - no, that's the drawback of powdercoating - it's bare clean metal only
BillActually you can sand it smooth and respray the powdercoat just like using primer to surface. I had a very pitted one off aluminum intake that my powdercoaters finished off like a nice enamel job! All you northern Ca guys check with Poly Engineering in Richmond. As I remember they did a set of four wheels, sand blasting and all for $110.00. I may be wrong,t that was a few years ago but I think that is what it cost. All I know is they were the absolute cheapest of MANY I called when I had my iron bed done (we are talking bedroom "Bed"  ) I had a number of things done by them and was very happy with price and quality.
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | Had my front axle, steering arms, knuckles & backplates done for $200 (blasting included). Not cheap but what a nice job. I might try MARTINSR's tip next time.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
