0 members (), 123 guests, and 5 robots.
Topics128,078
Posts1,056,035
Members48,433
#1156448 03/23/2016 2:18 PM
Ok I now have found the proper place to post this.
I took on a project that some one else restored and now I maintain. It is a 1954 3100 short box.
When I first saw it I noticed that the rear wheels were not centered in the wheel well opening. They set rearward of center about 3 to 5 inches. The owner had never noticed it until I pointed it out. It was obvious to me and the restorer whom I don't know nor have ever met. Why he didn't fix it IDK!
Anyway the owner let it set too long and the brakes were leaking fluid. I pulled the wheels and ordered 4 wheel cyl's. and a master cyl.. When I went to install the rear wheel cyl's., the ones I ordered were different than the ones on the truck. I had to take one to the parts house and match it up by visual lookup. The cyl.'s we now have show to fit a GMC and not a Chevy. (according to the parts book). Here is a picture of the wheel cyl. installed. http://i1070.photobucket.com/albums/u497/toyvo75/100_7234_zpsxymevod0.jpg
Here is a picture of the wheel opening with a chalk line showing center. http://i1070.photobucket.com/albums/u497/toyvo75/100_7209_zpsyihsyvxd.jpg
Here is a picture of the front of the drive shaft tube showing the amount of available travel at the slip yoke. (about 5 inches)http://i1070.photobucket.com/albums/u497/toyvo75/100_7235_zpshnzvbz2a.jpg
I have come to the conclusion that the springs have been installed backwards and this is causing 4-5 inches of being off center. Picture of rear diff and front of tube. http://i1070.photobucket.com/albums/u497/toyvo75/100_7226_zpsvqqjw4jx.jpg http://i1070.photobucket.com/albums/u497/toyvo75/100_7225_zpssgvdbtkd.jpg http://i1070.photobucket.com/albums/u497/toyvo75/100_7223_zpskasubdfc.jpg
A few pics. of the truck and the trailer is was built to pull. http://i1070.photobucket.com/albums/u497/toyvo75/100_7212_zpshyslo4qj.jpg http://i1070.photobucket.com/albums/u497/toyvo75/100_7211_zps52vg84zi.jpg http://i1070.photobucket.com/albums/u497/toyvo75/100_7217_zpsqj3mkje6.jpg.
http://i1070.photobucket.com/albums/u497/toyvo75/1954Airstream/100_7227_zpsdaf3urbq.jpg
http://i1070.photobucket.com/albums/u497/toyvo75/1954Airstream/100_7229_zpsyfzcgavn.jpg
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
Toyvo,
I think this is not a bendix-style wheel cylinder (Bendix style was used in 1954): http://s1070.photobucket.com/user/toyvo75/media/100_7234_zpsxymevod0.jpg.html
It looks like it has two adjusting/adjustment wheels/rings, like a huck-style wheel cylinder?
There might be casting codes on the rear end-housing - post what you find and someone might be able to decode it and determine the year.
Do the front wheel cylinders have one or two adjustment rings/wheels?
Figure 2. Huck style wheel cylinder...p through 1950) - two adjustment rings.
Figure 1. Bendix style wheel cylind...rom 1951 onwards - one adjustment rings.
The front seems to be Chevrolet, and has one adjuster independent of the cylinder located at the bottom of the shoe and the backing plate has 1 opening for adjustment. The rear has 2 slots for adjustment at the top of the backing plate and the backing plate is fixed to the diff. housing with rivets. That is why I think it is a GMC diff assy.
So do you think I am correct about the springs being installed back wards?
3B Offline
Hy Toyvo, in Canada all the 1/2 ton trucks Chev. and GMC from 1948 through 1955"A" have a 116" wheelbase. As tclederman pointed out the rear brake wheel cylinders are Huck type not Bendix which they should be, so I would surmise the rear axle is for a truck 1950 or older, possibly American GMC trucks have different wheelbases. The placement of the rear axle in an enclosed driveline setup is limited by the length of the driveshaft inside the tube, the rear axle must be positioned so that the driveshaft can engage the universal joint yoke at the transmission properly, there is not very much room to change the position of the rear axle and maintain the proper engagement of the driveshaft with the universal joint yoke. I would start searching for the proper rear axle with Bendix brakes and the correct wheelbase.
Bingo. That set a light on in my head. There were no long bed Chevrolet half tons in those years. That's why it has to be a GMC assembly.
However, according to Hollander, the wheel cylinder is the same, GMC or Chevrolet, half ton to 2 ton, 1937-50.
So I am still looking for what rear end this is and I found numbers here they are EE0612 found between the bolts that hold the diff. assy. to the diff housing. http://i1070.photobucket.com/albums/u497/toyvo75/100_7237_zpsgsz512bi.jpg
Also can anyone tell me by vin what this truck is? The owner says 3/4 ton from what I see it is a 1/2 ton. http://i1070.photobucket.com/albums/u497/toyvo75/100_7219_zpsqwoyrzdl.jpg
The code on your Vehicle Serial Number plate is: H54Sxxxxxx
H = 3100 (1/2 ton - all had 116" wheelbase)
54 = 1954
S = St Louis, MO assembly PLant
http://www.1954advance-design.com/chev-specs/1954-t-ser.jpg
1954 front brakes: http://chevy.oldcarmanualproject.com/shop/1954truck/54ctsm0502.html
EE0612
1947 3100 rear end
E = 1947
E = 3100
06 = 6th
12 = December
http://www.1954advance-design.com/chev-specs/1947-Chevrolet-t-ser.jpg
I think this is a different length torque-tube than used in 1954.
The 1947 rear brakes would be the 2-adjuster Huck-style brakes.
You might want to try to ID the transmission - post code/codes here.
How long has the present owner owned the truck?
Thanks, tclederman The front brakes appear to be correct. I have some shoes coming for a 48 to see if they fit better, maybe they are the same as 47. The torque tube being longer means the drive shaft is also longer so I guess we are in the market for a 54 diff. assy. The owner has had this truck about 6 years (he bought it as a basket case, dismantled) he has only had it restored for 4 years. I'll get Tranny numbers tomorrow and post here. Know any one in the Dallas, Houston, Shreveport area with a good 54 diff. willing to trade with some boot?
Toyvo,
You best bet is to post a Parts Wanted ad.
There are parts sellers who do not read posts outside the Swap Meet.
1941-54 Chevy 1/2 ton trucks use a Torque tube drive line.
3/4 ton and up are open.
The torque tube and the attached cast carrier housing probably is a 1947 torque tube.
The axle housing might be a GMC or someone put GMC brake cylinders on a Chevy axle.
This picture of your Torque tube makes me think its been tampered with.
It has 2 different size tube dimensions.
But then again I've never seen a 47 Torque tube.
The ones I have seen are usually one dimension, then tapers down to accept the ball housing.
One thing that stands out is the ball housing looks like it is barely slid onto the end of the Torque tube.
That means the rear yoke might not be slid far enough onto the propeller shaft splines.
The rear yoke might be just catching the end of the propeller shaft. Not Good.
Ilustration Scroll down. and HERE
Chevy 1/2 ton Torque tube length:
1947, 62 1/2"
1948-54, 60 1/8"
Parts Identification by ChevroLEE Some real good Data.
1929 - 1954 Master Parts and Accessories Catalog, Group Number 5.504
1929 - 1957 Chevrolet Master Parts & Accessories Catalog, Illustration
How to measure Torque tube
Your hunch is probably correct.
The rear axle leaf springs are flipped.
The article below kinda pertains to your situation.
1947-1954 Rear Spring Alignment
If you have a stock 1954 3 or 4 speed tranny they both use the same length Torque tube.
They are relatively easy to find.
But the 1948-53 axle ring and pinion has a 4.11 gear ratio and the 1954 axle has a 3.90 gear ratio.
Thanks jorb. I almost wish you had not posted this. LOL! Now I am going to remove the rear springs and see if the torque tube will slip forward enough to reattach the springs properly. So now I am torn between fixing the rear brakes on this axle and attempting to move it forward or replacing the rear axle with the proper 54 axle. On one hand replacing the axle will bring this truck just that much closer to a 100pt truck on the other I gain a 411 gear ratio. grin OH WHAT TO DO??? Wait! I know, I will just pull the 4 bolts out of the transmission and slid back the ball to see if there is enough room to slide the diff. forward FIRST! thumbs_up
Ok I have posted the want for a used diff. assy. but so far no takers. The truck is taking up much needed space so I reversed the springs, slid the axle forward about 4 inches and then lifted the diff. assy. so that the torque tube is in a straight line with the transmission and made sure I gave the shaft clearance at maximum extension. Then I lowered the diff. onto the springs taking care that the clearance increased as the diff. lowered. the locating pin is 1 and 7/8 inches forward of the hole in the axle mounting. I intend to build a mounting pin relocator from a 1/4 x 1 3/4 x 4 3/4 inch flat bar and allen head bolt or a 1/2 inch dowel. This should give me the clearance and put the axle forward about 4 inches (much better than before). Still looking for a diff. assy. but the truck is out the way. http://i1070.photobucket.com/albums/u497/toyvo75/Untitled_zpsjlz6ymjq.jpg
Anybody see why this wont work? The shaded area is where axle perch will be.I don't have a drafting program and did this in paint. So it is not to scale.
Just make sure that your dowel pin is very securely attached to your adapter plate. This is what keeps your axle attached to the springs when the rear wheels slam into an obstruction. Also understand that your truck will be lowered by 1/4 inch by your plate.
Carl
