2 members (Hotrod Lincoln, greenie-reddy), 96 guests, and 2 robots.
Topics128,049
Posts1,055,741
#115644 10/05/2003 11:19 PM
#115645 10/06/2003 11:37 AM
Get it apart and down to bare metal before you make that call. If you can salvage the originals you'll be ahead of the game.
#115646 10/06/2003 4:41 PM
Thats what I was thinking to. May as well do a clean up in the cab as well smile
#115647 10/12/2003 9:46 PM
Thanks for the replys. Next Friday I am pulling the engine out and on Sat I am putting a new one in. Pulling the engine should take no more than a couple hrs and once its done then I will tackle the cab. My plan is to remove the seat carpet and pad (whats left of it) and get my shop vac in there and clean up the immediate areas around the rockers. Once that is done I will start on getting the rust out of there. Then vacummn the rest of the truck. I will post some pics when I am done if all goes well with the engine swap out.
Thanks a bunch
#115648 10/16/2003 8:48 PM
Skokie, you from Illinois? I didn't see an address?
#115649 10/17/2003 5:09 AM
Naa not from illnois. Just a nickname. HAHAHAHA
