3 members (Gray_Ghost, Donsz, Gdads51), 92 guests, and 1 robot.
Topics128,056
Posts1,055,799
#1156399 03/23/2016 3:14 AM
So my master cylinder is empty, and my brake pedal stays on the floor after being depressed. Shouldn't the springs inside the bore of the MC push it back? If they're not strong enough, shouldn't there be a return spring on the pedal itself? I'm really only familiar with stuff from the 70's or newer. I haven't found any good illustrations showing that yet.
Crusing in the Passing Lane
Normally there is a return spring on the pedal arm, somewhere.
Ed
On a 55.2, should I be looking inside the cab, or under the floor?
Under the floor attached to the pedal going forward to the frame
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
Thanks! I'll check it out. I'm sure the pivot points are all a little rusty, but it didn't feel too difficult pushing it to the floor. I suspect something about the return spring is less than ideal.
The pedal return spring is located above the MC. It connects the pedal arm right above the pivot pin and goes back to the rear corner of the MC mounting bracket. You can see the spring if you look through the floor fill hole towards the frame rail.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
