| Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I just removed the cast part with the 3 bolt casting from an old housing and welded it on the correct bellhousing, Ni rod, pre and post heat, could also braze, used NP-540 trans.
Ed
