12 members (Hotrod Lincoln, TUTS 59, Gdads51, KEVINSKI, Dusty53, Lonnie, klhansen, Geo55, Gray_Ghost, Otto Skorzeny, 2 invisible), 149 guests, and 3 robots.
Topics128,165
Posts1,056,992
Members48,458
#1156142 03/21/2016 11:27 PM
V
VEW
Offline
V Offline
Is a way (for the average shade-tree mechanic) to check if an amp gauge is good or not when it's not installed yet? I know there's continuity, but how would I know if it reads current/flow when it's not installed yet?
As always, thanks.
~ Victor
1957 3100 - moved on
H Online: Content
Disconnect one battery cable on any vehicle you have handy, and fabricate a set of jumper leads from the ammeter to the loose cable end, and another circuit to the battery post, so any current flowing to the vehicle must go through the ammeter. DO NOT TRY TO START THE VEHICLE! It's OK to turn the ignition switch to the "accessory" or "ignition on" position. Turn on any accessories you can, such as high beam headlights, wipers, heater blower, cigarette lighter, etc. Depending on how it's connected, the ammeter will indicate either "charge" or "discharge". Reverse the leads at the ammeter, turn on the load again, and see if the needle swings the other way.
V
VEW
Offline
V Offline
Thanks Jerry. Exactly what I needed to know.
~ Victor
