9 members (John Dlugos, Buckeye998, Gray_Ghost, Gdads51, dt235sd, rfs56trk, BCBill, Otto Skorzeny, Dusty53),
236
0
Mod | | | Forums66 Topics128,101 Posts1,056,172 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | Can anyone tell me the diameter of the hole in the pitman arm (the arm that is connected to the steering gear box) where the ball that connects to the drag link is pressed into. This is for a 1949 chevy 3100. Mine is 5/8" but Jim Carter truck parts sent me two drag link replacement balls that have 3/4" shoulders where they press into the arms.
Is my arm wrong or is their part wrong. I see classic parts sells one with a 5/8" diameter shoulder | | |
