1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 92 Shop Shark | | Shop Shark Joined: May 2014 Posts: 92 | This 235 was in my 58 half-ton short step side when I bought it, but I have no idea if it's the original engine. The number stamped on the machined pad to the rear of the distributor is F072IA. It's an I rather than a 1. Can someone decode this for me or share a link? I spent about 30 minutes searching old posts and spec manuals, but could not come up with the right info. Thanks for your help. EDIT: Casting number is 3769716 which is a 58-62 235 according to the chart I looked at. 2nd EDIT: well, bust my britches, the I IS a1, and I found the info in the post right above! I tried to delete this but it won't let me, so Never Mind. If I'm reading right, it's a 60 235 engine.
| | | | | Joined: May 2014 Posts: 92 Shop Shark | | Shop Shark Joined: May 2014 Posts: 92 | I looked at the post from GMONIZ. I selected "casting codes". I then went to "block codes and series sequence codes". I followed the table down to "235" and saw that for 1960 the stamped code for my block casting number(3739716)started at F 0361A and ended at F 1203J. That's what it looked like to me anyway. Is that the way you read it? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Tim, No - I do not read/see 1960 specified in anything you posted. If I am wrong, someone will post a correction. 3739716 - was used from 1958 through 1962 on all truck 235 engines and some car 235 engines. From 1958-1962, the Engine Serial Number was not useful in IDing the year-date of an engine, because same codes were used in several years. and no year information was in the ESN. F 0361A - F 1203J The A & the J at the end of the ESN is a model code. The model codes were often the same in 1958-1962 years. The A model code was used for a car engine 235 engine from 1958-1962. As I posted above, if you want to know the year, you will have to find/post the Date Casting Codes for the head and the block. The locations of date codes are shown here. Here is a page with links to serial numbers/codes for many years cars/trucks. Here is a page with casting codes for many years cars/trucks. | | | | | Joined: May 2014 Posts: 92 Shop Shark | | Shop Shark Joined: May 2014 Posts: 92 | Thanks for taking the time to set me straight. I will go gather the rest of the numbers. | | | | | Joined: May 2014 Posts: 92 Shop Shark | | Shop Shark Joined: May 2014 Posts: 92 | Ok, I got the casting code and it is G 19 0. If I'm doing this right, that's July 19, 1960. That means I was reading the chart referred to above correctly or I got lucky. At any rate, thanks for all the info. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, that information specifies a 1960 block date casting code, and that code confirms the year of that 1958-1962 235 car engine block.
